Old 12-30-2014, 08:15 PM   #1
jwaldrich
jwaldrich's Avatar
Question New Rear Hub
I've read a fair amount and I keep coming back to the statement about "matching shoes to hubs".
I purchased a new hub and discovered it will not fit over the brake shoes.
Is it common to have to mill a new hub in order to install it with good to new shoes?
Thanks in advance.
John from Kapowsin
T&A Guy
jwaldrich is offline   Reply With Quote
Old 12-30-2014, 08:26 PM   #2
Mitch//pa
Default Re: New Rear Hub
when you say hubs do you mean drums? or new drums with hubs? is this for front or rear or both? which ones are you having trouble with?
Old 12-30-2014, 08:26 PM   #3
edmondclinton
Hub?
You mean drum.
Make sure the adjusting wedge is backed off so as not to expand the shoes. Then see if the drum will go on.
edmondclinton is offline   Reply With Quote
Old 12-30-2014, 08:27 PM   #4
redmodelt
redmodelt's Avatar
? Are you asking about brake drum or hub itself. The statement should be matching shoes to brake drum. If you had a new brake drum mounted to your hub then the drum needs to be turned to be centered to the hub. If you got the new drum/hub from Snyders, it's preturned and ready to bolt on. In eather case the shoes need to be checked for fit to the drum(s).
Old 12-30-2014, 08:32 PM   #5
jwaldrich
jwaldrich's Avatar
I'm sorry. Yes I mean rear drum.
John from Kapowsin
T&A Guy
Old 12-30-2014, 08:38 PM   #6
Mitch//pa
so what was done?? new rear shoes? new emergency shoes? new hub and drum? new drum swedged to your old hub? was the hub and drum trued?
more info can help us help you
Old 12-30-2014, 08:41 PM   #7
Charlie Stephens
You have the shoes arced (ground down) to match the hub. Try your local clubs and see who does it in your area. Between disc brakes the EPA and OSHA it is hard to find someone with the machines to do this. Also check with the place your purchased your shoes and see if they can do it or send them back to the place that relined them for grinding.
Charlie Stephens
Old 12-30-2014, 08:42 PM   #8
jwaldrich
jwaldrich's Avatar
Originally Posted by edmondclinton View Post
Hub?
You mean drum.
I "played" with that and I am thinking they are backed off about as far as they will go. I turned it counter-clockwise to back it off.
How far can you go?
John from Kapowsin
T&A Guy
Old 12-30-2014, 08:45 PM   #9
Mitch//pa
it is probably hanging up on the e brake shoes
Old 12-30-2014, 08:56 PM   #10
jwaldrich
jwaldrich's Avatar
I bought a new drum with the hub swedged to it.
I had excessive axle end play and was attempting to fix that. Tore rear end completely down, replaced ring and pinion gears (broken tooth on ring gear) and replaced one axle. It bought a used axle but in very good shape sold to me by a local, well respected guy who deals in used Model A parts.
Put new bearings and double race in banjo where the drive line goes through. New drum also got new bearings etc.
One drum showed "rubbing" inside against the face (backside of the lugs). This is the drum I replaced with new. I took the brake assemblies off as a unit so no brake work was done. The brake shoes show little to no wear.
John from Kapowsin
T&A Guy
Old 12-30-2014, 08:57 PM   #11
jwaldrich
jwaldrich's Avatar
It is hanging on the brake shoes which is why I posted the original question.
John from Kapowsin
T&A Guy
Old 12-30-2014, 08:59 PM   #12
Mitch//pa
after the new drum was swedged did it get trued and resurfaced?
Old 12-30-2014, 09:02 PM   #13
1930artdeco
1930artdeco's Avatar
did you A: turn the drums to true them up and B, the shoes may need a small amount of arching to them. It depends on if you are using bonded or woven. But either way i think those two items will fix the problem.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 12-30-2014, 09:08 PM   #14
pgerhardt
pgerhardt's Avatar
I think what Mitch was trying to get across with an economy of words is that the E (emergency) brakes are not effected by the adjusting wedge and may be partially applied. Check to make sure they are not.
pgerhardt is offline   Reply With Quote
Old 12-30-2014, 09:15 PM   #15
Mitch//pa
new drums come manufactured thicker to allow for resurfacing and truing. if they were not done they may just be to thick. thats why i asked if they were machined after swedging.
Old 12-30-2014, 10:02 PM   #16
edmondclinton
The inside diameter of the drum is supposed to be 11 inches if memory serves me correctly.
Old 12-31-2014, 12:27 AM   #17
Kurt in NJ
Kurt in NJ's Avatar
Perhaps the old drums were worn and thicker lining was used
Old 12-31-2014, 10:51 AM   #18
jwaldrich
jwaldrich's Avatar
The new drum has NOT been turned so that is undoubtly the problem. Will see about getting that done today.
John from Kapowsin
T&A Guy
Old 12-31-2014, 11:01 AM   #19
Mitch//pa
yes i would and even if it did fit over the shoes they need to be trued to the hub after swedging or most likely it will pulsate badly on braking
good luck
Old 12-31-2014, 11:33 AM   #20
Dick M
Dick M's Avatar
Send a message via Yahoo to Dick M
You must center the brake shoes to the axle housing. The drum will may not clear the shoes if they are to low or to high on the axle. You can purchase a brake centering tool from most Model A suppliers.
Dick M is offline   Reply With Quote
