Old 12-03-2014, 02:27 PM   #1
Fullraceflathead
Fullraceflathead's Avatar
Default Intake Manifold without Pipe Threads for Vacuum port.
I just bought an Intake Manifold without any threads tapped in it for the Vacuum port for the wipers.
Would this be an early 1928 Manifold???
I bought it thinking it is an early one and since my '28 Roadster Pickup came with a mechanical wiper it might actually be correct for it.
It does seem odd though that they would have kept engines with and without tapped intakes organized just to match certain Models on the assembly lines when you consider the Volumes of Cars being built each day.
Fullraceflathead is offline   Reply With Quote
Old 12-03-2014, 02:59 PM   #2
Farrell In Vancouver
Farrell In Vancouver's Avatar
Default Re: Intake Manifold without Pipe Threads for Vacuum port.
A lot of early closed cars came with electric wipers and did not require the vacuum port.
Farrell In Vancouver is offline   Reply With Quote
Old 12-03-2014, 04:08 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Yep, as I recall all of 1928 and early 29 had no threaded vacuum port. That makes it tough to install my wolf whistle, because I won't drill holes in an original part that never had the hole.
Old 12-03-2014, 04:21 PM   #4
Russell in Tulsa
Hey Tom, Fullraceflathead sounds like he may have an extra manifold soon with the vacuum port.
Russell in Tulsa is offline   Reply With Quote
Old 12-03-2014, 04:35 PM   #5
Fullraceflathead
Yep!
Old 12-03-2014, 08:31 PM   #6
SteveB31
SteveB31's Avatar
No intake had a vacuem port until late 1929. Since they had yet to sell a Model A with a vacuem wiper.
SteveB31 is offline   Reply With Quote
Old 12-03-2014, 09:18 PM   #7
wrndln
There are plenty of intake manifolds around that have vacuum holes in them, so I wouldn't drill a hole in an intake manifold that doesn't have a hole in it - save it for someone with a 28 or early 29. I have seen to many manifolds drilled and tapped and usually not in the right place - many times on the top.
Rusty Nelson
Old 12-03-2014, 09:38 PM   #8
Marco Tahtaras
Marco Tahtaras's Avatar
Is the manifold embossed in the location for the vacuum port but undrilled, or is it simply plain with no hole OR embossing?
FYI, 1927 and very early '28 (January?) did indeed have a 1/8" pipe fitting hole.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 12-03-2014, 09:42 PM   #9
Purdy Swoft
Purdy Swoft's Avatar
My september 29 didn't have a vacume port in the intake when I got it. I suppose if you need one with a vacume port I could maybe trade one with you. I like the ones without the vacume port. I'll check my intake manifold collection.
Old 12-04-2014, 11:52 AM   #10
Fullraceflathead
The manifold is smooth where it would normally be drilled and tapped. I don't see any extra material on it to support it being drilled.
This is why I bought it. I'm hoping it would be for a '28 or '29 as my '28 Roadster Pick up has the manual wiper blade as all of the commercial trucks came as I believe.
Old 12-04-2014, 12:16 PM   #11
Fred
Does it have a large "HUMP" right at the top of the intake port ?.. If so, that is an early one.. If not it would be the regular one used from March 1928 until about mid 1929 ..
Fred is offline   Reply With Quote
Old 12-04-2014, 12:52 PM   #12
Bruce
Bruce's Avatar
As I recall, the Restoration Guide and Judging Standards has a chart to make it easy to find the correct manifold for your car. The un-bossed, untapped manifold that looks nice hanging on our June '30 Station Wagon (with electric wiper) is "wrong."
Drat! I shouldn't have told you all. You'll pick "Kingsford" apart next summer at the Friday night old car gatherings.
Bruce is offline   Reply With Quote
Old 12-04-2014, 01:06 PM   #13
Purdy Swoft
The undrilled and tapped intake manifolds usually bring a higher price than the later more common intake manifolds.
Old 12-04-2014, 02:01 PM   #14
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Yes. FWIW, I just received an Engineering Release on the A-9425 that shows a revision on 3/26/28 that says "Remove boss and 1/8 pipe tapped for vacuum windshield wiper.". Evidently on 8/26/27, a revision was made that stated "...and added 11/16 diameter boss and 1/8 pipe tap for windshield wiper suction line."
Therefore, depending on production change dates, and the levels of inventory on hand at the Branches, it is likely that some April and maybe some May cars had that manifold too.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 12-04-2014, 02:09 PM   #15
Fullraceflathead
The Manifold is smooth on the top surface, there is no machined boss or material on it.
