Is there more room i.e. body to steering wheel in the Roadster then in the Closed Cab Pickup 1930/1931?
Yes there is more room in the 30-31 roadster than the pickup . The seat back is adjustable to some degree in the roadster . My standard roadster with the taller top is very comfortable to me and I am 6.2. the taller top makes it easier to enter and exit than a deluxe model and I prefer the look
Thanks Purdy sure appreciate the response. Any idea how your Roadster compares to the Roadster Pickup in room ?
I don't know from experience because I don't have an open pickup but I suspect that the pickup is closer
The Roadster pickup is a challenge to get in and out of unless you change the top to fold down, being 6'2 made it difficult
Wayne |
Cape Codder,
I am 6 ft and have a Roadster Pickup. I have not compaired it to a CC Pickup as I have not seen one here in Cape Town. Mine is a RHD with the spare in the left front fender, which means the driver door can open slightly more. I trimmed my seat back foam down to about an inch, which made a big difference in leg room. Obviously the seat back does not help getting in or out and since I fitted the hood it is rather A tight fit. Regards Chris Cape Town |
A friend of mine owns a 28 roadster pickup, on the occasion i drove it ,i found it hard to get in and out of it. I am not that big of a person , i think people were smaller back then. Also the 31 Phaeton was also difficult to enter and exit. I own a 30 coupe and it is much easier to get in and out.
The narrow doors make it harder to enter and exit the roadster and roadster pickups.
It is easier to get in the passenger side of my CC. Spare on left makes it VERY tight.
Yes folks were smaller and so was I 25 years ago ![]() |
Because of parallel parking back in the day, I think that entry was suppose to be on the passenger side
There is adjustability of the seat back on STD roadsters ? Hmm, I'll look but never noticed anything on mine.
I really don't have a problem getting in or out of them [ I'm 6'1" and swelling a little more around the middle each year], but, its kind of a learned experience over the years. I wonder if there is a real problem with that, if a shorter steer column would help. |
#13 |
Marco made this illustration that I think shows the relation between the Pick-up and a Roadster very well. (the seating between the open & closed cab is the same).
#14 |
#15 |
Well, think about the length of the pick-up bed, and then locate it by way of aligning the two rear fenders, then see if the same does not hold true!
#16 | |
![]() Quote:
#17 | |
![]() Quote:
As usual, this sounds Purdy good. Thanks. I've not had the need to look and have not done anything in that area. My Brattons book is a couple years old and doesn't seem to show that, but, thats OK. I'll go and have a look probably in the spring. Too darn cold up there right now. |
#18 |
Before I bought my Tudor I was at an AACA meet. Saw a ccpu and a roadster pick-up. I 'm 5'10" and could get into the CCPU (30) but it was tight after getting in. The rpu I had great difficulty getting in and then couldn't bring my legs up to work the cluth or brakes (29). Got into a coupe and no problems, same with a four door. The front seat in my 31 Tudor is moved back about 6" and is fine once I get in (harder now since the hip revision surgery). The owners of the cars were very gracious in letting me ck them out.
Paul in CT |
#19 |
I think that the 1928 thru june 1930 open pickups are closer than the later 30-31 pickups.
#20 |
I have a 28 roadster and a 28 CCPU .
It seems like I fit in the CCPU better , even though there is less room from seat back to wheel . Maybe it is just because it is far easier to drop inside the CCPU with the much larger door and possible wider between the inside doors to stretch a bit more sideways. Will run a tape over both of them when down in garage . edit, checked width, at upper arm/shoulder height, the CCPU is one inch wider, it seems more. Last edited by pooch; 12-03-2014 at 09:38 PM. |
