Old 10-13-2014, 09:27 PM   #1
gearheadbill
gearheadbill's Avatar
Default more roadster help needed
Working on a 29 roadster and have another question.
There has to be some kind of doubler or nut plate that goes behind the A pillar where the windshield posts go that allow the post screws to thread into. What does it look like? I can certainly make something but it would be nice to have an idea what Henry did. Thank you.
I have attached a couple of pics of my reproduction body. A picture of what it's supposed to look like would be nice if anyone has one.
gearheadbill is offline   Reply With Quote
Old 10-13-2014, 11:48 PM   #2
Randy in ca
Randy in ca's Avatar
Default Re: more roadster help needed
Here's what the originals looked like. The two outer holes are threaded and the middle one is used to rivet it in place. The bolt holes are not parallel on either plane so might be tricky to make up. I would check with Brookville - they must have something to use there.
Randy in ca is offline   Reply With Quote
Old 10-14-2014, 09:01 AM   #3
gearheadbill
will do. Thank you
