Three or four years ago I had my Tudor engine rebuilt by a local reputable Model A guy. But it never felt quite right to me; though it had a lightened flywheel and balanced and weighted crank, it felt out of balance. I talked to the builder, and he assured me everything was as it should be, including the balance. Two weeks ago I took it on a long tour, and it had what I would describe as a harmonic vibration at about 27 mph and 47 mph, and the usual uneven feel at all speeds.
I couldn't stand it any more. Last Friday I pulled the rear end to check the balance marks on the crankshaft, flywheel, and pressure plate. To my surprise, everything matched as it should. I put it back together -without changing anything- and took it for a long drive today. And what? Now it runs smoothly and with none of the previous vibrations! I'm pleased, but I can't figure out why it turned out that way. ![]()
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. ![]() |
Be sure to hang a bell under the car to keep the road gremlins away now that it's running better.
If you took the flywheel off you may have put it back on the engine 180 from where it was when you took it off. It may have originally been balanced as you have it now.
Tom Endy |
Thats about the only thing that it could be
That's what I thought before I took it apart. But when I opened it up the balance marks were matched, and I put it back in the same way.
#6 | |
But then, in that case, I would still have the problem which was somehow solved by taking it apart and putting it back together. Very strange.
Possibly psychological ! Now that you are satisfied it was done correctly your mind is at ease. Cures don't happen without a change being made as stated above. Accept it fir what it is and don't forfet the gremlins !
Wayne |
#8 | |
![]() Quote:
![]() ![]() That would be like Ford calling the Thunderbird the "Turdbird". ![]() Maybe that was their undoing. ![]() |
Kind of like my ford falcon.....it quits so I loosen all the screws in the distributer and re tighten them all back up and then it works again! Beats the hell out of me why it does that, I even installed all new parts
Actually a company does call some of their vehicles turd's. Toyota TRD.
#12 | |
![]() Quote:
Maybe there was a little piece of something on the crank flange when the wheel was first installed and now its gone due to the R&R. Or, maybe its just another of lives little wonderments. I had kind of a similar issue. When I first bought this monster in '76, it always had a bit more of a vibration than I thought it should have. Due to the monstrous clutch chatter I replaced it and reinstalled the flywheel the same as I took it off. Chatter gone, vibration still there. I took it apart years later and while readjusting the pressure plate I noticed 3 punch marks on the wheel and then found 3 corresponding marks on the flange. These marks were not very pronounced. These were 180 out from how the wheel had ben installed. I installed the wheel according to the punch marks, vibration gone. |
#13 |
Ray, sometimes you just have to accept the small victories when they find you.
I have a recently rebuilt touring ( all balanced, etc. ) diamond block motor in my Tudor that has a resonance at 47 MPH, and vibrates a lot above 45 MPH. But it isn't excessive, so acceptable. My friend just dropped a rebuild in his Fordor that isn't even balanced, but does have inserts, and his motor is silky smooth. There is simply no logical explanation, it is what it is. |
#14 |
#15 |
Yup Car Gremlins!! Sometimes you just can't figure it out. I'm working on a 29 Woodie right now and some times it fires right up and runs and the next time no spark. Something in the wiring as everyone and his brothers been into it in the past. Maybe start with a new wiring harness.
The Old Tinbasher |
#16 |
Start taking things a part in the house; like the confuser...
#17 |
A story told to me about a new car vibration.The fix was replace the
rear end with another new car rear end vibe gone,now put the original rear end back in,no more vibration! Sometimes parts are not happy in their home just need to move things around :-) |
#18 | |
![]() Quote:
Just had similar problem with a new original style distributor. The lower primary lead seemed fine ,but, a little tugging and pulling would allow the wire to go open. A little extra solder fixed that issue. The end connector also appeared as though it could have intermittently contacted the coil tension spring, a bit more bend fixed that. Car has been running fine since. That said, intermittent problems can lead to premature hair loss. I'm proof. |
#19 |
There was likley apiece of dirt under the flywheel on the crankshaft flange, that was not there when you put it back on.
#20 | |
![]() Quote:
