The Model A Mechanics Handbook by Les Andrews says nothing about indexing the pump with the cam gear? And forbids doing anything with the plug on the block along the oil pump. Perhaps that automatically takes place by the pressure of the oil pump spring. also The Complete MOdel A Ford Restoration Manual by Les Pearson, say do not unscrew the plug along the block near the shaft of the oil pump. Just pretend that it does not exist.
Strange that two experts of the model A are names LES! I am sure someone out there has replaced a Model A oil pump. How did you reinstall it? Does the upward pressure from the oil pump spreing automatically push the top slot of the oil pump into the proper cam?? Whats the real story? Should I just junk my car and buy a Ford Pinto? |
remove the plug. run an 1/8th pipe tap part way in, but not too far as to interfere with the pump shaft. When you install the pump, set the slot approximately where it will align with the tab on the dist drive gear. Rotate the pump housing back and forth lightly until the housing detent drops into the hole. Then reach up and tighten the tap so it will hold the pump in place. Install the pan, remove the tap and replace the plug.
#3 | |
![]() Quote:
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. ![]() |
Ha Ha I have a 1933 model B, if the model A engine is too much trouble maybe I will replace it with the v8.
Here is how I do it. Use a bit of paper to wedge the pin on the pump into the respective hole in the block and replace the pan, It is too simple! pre-fit the shafts or turn the engine till the shafts drop together.
Remember, the gasket needs to be installed to the block along with the end corks, and NOT to the pan. |
Great info.
I am asking this because I have a problem with the pipe plug on my motor. The plug won't come out, I tried everything. So I am looking for alternatives to do the job without having the plug hole. The last thing I want to do is damage the plug and have an oil leak. Thanks a million, you guys are great! |
I figured that might be the case. I too wouldn't try to remove the plug, but just hold the pump with the wire I mentioned or the paper in the peg that J Franklin mentioned.
#9 | |
![]() Quote:
I hear the term short block? What is that? Is that for smaller pistons.
#11 | ||
![]() Quote:
I greatly appreciate everything you guys have done for me! My oil pan is so badly clogged that even new oil i added won't drain out the oil pand drain hole. I have the pan supported by a jack and i know i will have a mess when that pan drops. to be so badly plugged I am scared what i will find when i drop the pan?? I will let you know.
#13 |
#14 | |
![]() Quote:
It usually means the block with crank, pistons, rings, and rods installed, along with the valves, lifters, springs and camshaft along and the timing gears. |
#15 | |
![]() Quote:
http://antiqueenginerebuilding.com/MODELA.html |
#16 |
Put a container under the pan and run a bent wire through the drain hole up into the sludge, it should start it coming out.
#17 |
My thoughts exactly !!! I've seen engines where the oil wouldn't drain out the drain plug hole but never a time that a little digging around in the drain hole with a wire or small screwdriver wouldn't get the oil to begin draining .
#18 |
#19 | |
![]() Quote:
YOU should be scared ![]() ![]() ![]() |
#20 | |
![]() Quote:
Anyway, the pan get dropped tomorrow...I hope I survive! |
