Just changed my sealed beam conversion back to stock headlights using the new Brattons reflectors, Holy Crap! These are amazing! I'm gonna buy a set for my 28 sport coupe! They are crazy bright and I'm running 6v with stock bulbs!!!!!! I highly recommend them!!!!!!!
#2 | |
![]() Quote:
Nothing can be made foolproof, ---- fools are ingenious bastards. |
#3 | |
![]() Quote:
Bulbs with properly shaped filaments wall also add to the whole package.
Hi 58,
FWIW: The July/August 2014 Restorer printed an article by Mr. David Adair, Oregon City, Oregon, where Bratton's reflectors with 32 candle power (CP) bulbs, (either 6V or 12V), reportedly had the: "Best well defined light pattern" at 25 feet, & was the only one rated as "Excellent". It was reported that Bratton's Aluminized reflectors rated even better than original polished silver reflectors; and, that the 32 CP bulbs focused better with these reflectors at 25 feet than that of the 56 CP Halogen bulbs with Flash Chrome reflectors at 25 feet. |
#5 | |
![]() Quote:
This will be the third time I have asked this question without a reply, using a quality bulb such as a Mazda 1000, ---- not the offshore no name brand, as anyone bothered to check the beam adjustment as per factory pattern,
just curious.
Have they straightened out the issue with the bulbs not fitting properly in these? The last ones I bought from Walt a, few years ago, blink on and off because of poor bulb contact.
'31 40B '31 68C |
#9 | ||
![]() Quote:
A few years ago these were just on the drawing board. As I recall, these have only been on the market for 6-8 months, ...maybe a little longer. |
#10 | |
![]() Quote:
I can actually see where I'm going. Al Leach |
you guys have answered a huge question I had because on the present reflectors I have, wherever they came from, I never have been able to get the focus pattern depicted in the Service Bulletins.
give an ignoramus like me some more information....if this is a modern run, where do you buy them?
#13 | ||
![]() Quote:
Like the initial post eluded to, these are the newly tooled headlight reflectors that Brattons came out with recently. HERE is a link to them on their website. |
#14 | |
![]() Quote:
#15 |
Is there a writeup that compares these reflectors with original stock in terms of performance? I have been thinking about having my originals replated. I understand about the tarnishing difference but I am more interested in knowing if these provide better light. Brattons catalog says reflectivity is the same as silver
#16 | |
![]() Quote:
#17 | |
![]() Quote:
#18 |
The article by Adair is great- very well done, but has a 'hole'.
He left out the direct replacement halogen bulbs that are on the market. These are the bulbs that fit the original socket and should have the filaments reasonably located such that you can properly focus the light. The halogen he tested was the modern type which can not be focused. So you waste a lot of light (which means your blinding oncoming traffic and lighting up the trees) so the amount of light at the sensor was not that much. So you spend a lot of money for the kit and you need to have more electric power to run them. So you need to spend a lot of money and the article shows you do not really gain anything. The direct replacement halogen bulbs should be at the correct focus point and would likely show a substantial improvement in light output with minimal increase in power required. I believe there are 2 manufacturers of the direct replacement halogen bulbs. There are the lower cost made in India bulbs. The few bulbs I have seen of this type have a plain brass base and you can see the filaments are not positioned properly. These bulbs I believe are imported by Hirsch and the major A vendors are selling them. The second company is Classic and Vintage Bulbs. The older bulbs are dead on replacements for the originals as far a filament placement. My understanding is there has been a change in the place of manufacture and the quality is not the same. These bulbs are only available from some select dealers. |
#19 | |
![]() Quote:
![]() HOW MUCH OF THE LIGHT IS FOCUSED vs. SCATTER? Here's one way to figure the %. Refer to the diagram below. Measure the distance from the filament to the edge of the reflector. This is the RADIUS. Measure the angle from the center line @focal point to the reflector edge. This is THETA. Compute the surface area of the sphere of total photon emission, outlined by the red circle. A = 4pi x r x r Compute the surface area of the cone of unreflected photon emission, shown in yellow. A = 2pi x r x r (1- cosine theta) Use the two areas to calculate either the direct or reflected %. (simple arithmetic!) ![]() Side note here: 1) Not all of the light that flares through the lens (blue) without parallel reflection is bad! All of the scatter light below the centerline is useful road illumination. You may consider using 1/2 the area of the unreflected cone of emission when figuring % of useful light. 2) The 60/55W lamps with the BLOCKED forward emission eliminates much of the unfocused forward scatter, but does not reflect that light back to the reflector. The black top converts visible photons to heat. Is this good or bad? You eliminate the annoying upward scatter that illuminates trees, but you also lose the useful down-scatter that illuminates ground close to the vehicle. On a positive note, there will be less glare to oncoming traffic. The low beam filament internal reflector will severely bias which section of the Twolite lens receives the most light. Beam pattern result unknown without field test comparisons. |
#20 |
