Distributor acts like a uneven cam as I rotate shaft .that is one lobe is 30 thou next lobe 20 thou and so-on...tried two cams both similar checked shaft play seems real tight ? whats going on here ???
Bushings not reamed in the center.
Received this PM Hi Mike, The bushing is fixed so if it were off center, it would not impact the varying gap as the center of the shaft stays at center of reamed bushing. I have seen the cam machining on new distributor shafts be off (concentric)as much as .004" which translates into .008" when spun 360 degrees. Given some old cams were also off, it is possible the two are adding...but the amount he is observing seems over the top of possibility. Good Day Mike! Dave Gerold
What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do some thing about them. - Henry Ford II Last edited by Mike V. Florida; 06-11-2014 at 04:00 AM. |
Center hole in upper plate may be a sloppy fit to the casting. Peen around plate hole to tighten it if there is any sideways play. The three tabs that ride in the slot are NOT what holds it centered.
When this happened to me the shaft was worn out .!! Crap repro part that had only been in there for 500 miles.
Have you removed the distributor ? to check that the shaft is tight in the distributor bushings no sideways play !! John Cochran |
Couple of years ago we had the same problem with NEW top shaft , seems when they were machined out of round & one point reading was 5-7thou less than the other 3 ,contacted the supplier, they airfreighted another batch from a differant supplier , same thing , their 3rd supplier was able to send yet another batch of which checked out correct ,Mac,s often send me parts to check , So i beleive you have an out of round shaft where the rotor fits , We set them up with a dial guage kit i purchased at a National meet , Hope this helps , Derek from still wet NZ
Derek, most of the wet here on my manor is coming out of a can, we sure could use some of your rain. Regards Brian.
Nothing can be made foolproof, ---- fools are ingenious bastards. |
Brian Ill deliver some in Feb, ?? My devise is a clamp that fits on the dissy, with various hole in the side of which your dial gauge fits in, can measure point gap, cam run out , etc, that's how we picked up out of round shafts only where the cam fits on, this area has been machined down to take the cam ,
#8 | |
![]() Quote:
Also check the distributor cam with a micrometer... Most repro cams are not made accurare on the lobes. Try to stay to an original parts.....hope it helps
Hmmmmm ! Good Post! I am having some ignition issues that seem like they may be caused by this too. But I said" nahhhh, that couldn't be!" But I see now how it could be. Just bore the hole in the cam a couple of thousandths off true center and she will not ever run right! Sloppy machine work will do it every time!
Terry |
Find someone with a Distributor machine,..it solves a ton of problems.
I've used mine for the past 40+ years.... |
this thread makes me wonder how they ever kept these cars running 85 years ago. must have been wizards with that tool kit.
#13 |
#14 |
The model A was built for the common man . The common man could understand and do things that most of the people that now have model A's can't understand or do.
