Old 06-10-2014, 09:20 PM   #1
Gold Digger
Default Lube for gas shut off valve
Does anyone know of a lube for shut off valves? The valves on two of my "A's" are real hard to turn and one is a new one. Also I'm having trouble with a tapered plug valve on a "B" John Deere. I was wondering if I rubbed some kind of soap on them if it would stay on them and not cause troubles else where. I know soap will work in an emergence when you knock a hole in a gas tank and gas don't break it down. Maybe someone knows of something made just for the business.
Gold Digger is offline   Reply With Quote
Old 06-10-2014, 09:41 PM   #2
Fred
Default Re: Lube for gas shut off valve
It comes in Brattons rebuild kits..
Fred is offline   Reply With Quote
Old 06-14-2014, 09:35 PM   #3
Drive Shaft Dave
Question Re: Lube for gas shut off valve
I think one of the Model T suppliers sells such a product, Lang's Model T Parts. Kind of pricey though.
Drive Shaft Dave is offline   Reply With Quote
Old 06-15-2014, 08:06 AM   #4
Gold Digger
I bought some stuff that was for lubricating gas valves but it didn't last but two days and it became hard to turn again. I didn't find any EZ-lube but still looking.
Old 06-15-2014, 09:15 AM   #5
leadpot
leadpot's Avatar
Found that when I use regular (ethanol) gas the shutoff valve becomes difficult to turn. When using non ethanol (premium) it becomes smooth again. The ethanol must affect the o'rings in some way. Not sure if they expand or ???
leadpot is offline   Reply With Quote
Old 06-15-2014, 09:25 AM   #6
redmodelt
redmodelt's Avatar
A stock shut off valve does not have o-rings. It's a tapered fit and uses graphite packing like the water pump.
From the model T forum;
I worked "Plug Valve Grease" into the felt before installing on line. That's the same stuff that is also called "Gas Tite Grease" and is designed to lubricate fuel valves. The felt seal has been in service for 15 years now with nary a hint of a leak.
I also lubricated the (original) valve with the same grease. It's getting a little hard to turn now. Guess lubing it once every 15 years isn't too much to ask.
Ignore the part about felt packing/seal.
Old 06-15-2014, 10:16 AM   #7
FL&WVMIKE
FL&WVMIKE's Avatar
Good ole WD-40 might work. Even if you had to use it every time you went out.
MIKE (mikeburch)
FL&WVMIKE is offline   Reply With Quote
Old 06-15-2014, 01:10 PM   #8
Raven
We used a cock grease in the Shell oil refinery I used to work at that was gasoline proof as it wasn't hydrocarbon based...we ordered it from a company here in Houston called "Val-Tex"...I'm to call them and see if I could purchase some over the counter...
Raven is offline   Reply With Quote
Old 06-15-2014, 05:35 PM   #9
Pinstripe
[QUOTE=1930 coupe;892395]Do a Google search for fuel lube and you will find several.
http://www.aircraftspruce.com/catalo...ezturnlube.php[/QUOT
I checked out this site and found the fuel valve lube and a corrosion preventer and safety wire and pliers. Good site thanks
Pinstripe is offline   Reply With Quote
Old 06-16-2014, 10:45 AM   #10
john in illinois
john in illinois's Avatar
I use the ez turn fuel lube also on my 30 gas cap gasket and radiator cap gasket.
Takes less effort to get them off.
John
john in illinois is offline   Reply With Quote
Old 06-16-2014, 02:36 PM   #11
MikeK
MikeK's Avatar
What works a long time (years) for me is powdered graphite during assembly with NO grease or other lube. I rub it on and rub it in 'till the surfaces are shiny gray. It does not wash or dissolve in gas, and if any of the powder gets through into the carb and engine, it is harmless. I suppose powdered Moly-D would also work.
MikeK is offline   Reply With Quote
