Old 05-18-2014, 11:14 AM   #1
Lee Mitch
Default Stalling while coming to a stop
If I run my GAV any less than 1/2 a turn open, my car stalls when coming to a stop. Then it idles bad (too rich) until I close it. So, every time I come to a stop, I have to mess with the GAV. Do you think the float is incorrectly set? Other suggestions?
Lee Mitch is offline   Reply With Quote
Old 05-18-2014, 12:06 PM   #2
ford3
Default Re: Stalling while coming to a stop
that would be my guess. float to high and flooding engine when you stop
ford3 is offline   Reply With Quote
Old 05-18-2014, 12:18 PM   #3
pat in Santa Cruz
pat in Santa Cruz's Avatar
Among the myriad causes of this common condition, see poorly adjusted float, clogged idle jet. This condition is also associated with a vacuum leak. Aside from the obvious leaks in the vacuum system (tubing, fittings, windshield wiper) check manifold and carburetor gaskets. Check to see if the carburetor flange is flat, not warped. Check to see if your throttle shaft is loose in the carburetor body. That is often overlooked, and it certainly will cause it.
try this site for diagnosing it:
http://modela.org/engine_dies_stop.html
pat in Santa Cruz is offline   Reply With Quote
Old 05-18-2014, 12:32 PM   #4
Purdy Swoft
Purdy Swoft's Avatar
Usually it will be incorrect float level. Being as the GAV has an effect it could well be a problem with the idle jet as Pat mentions above in post #3. Richening the GAV could compensate for a lean condition caused by a blocked idle jet.
Old 05-18-2014, 05:47 PM   #5
V4F
V4F's Avatar
what carb ?
V4f
V4F is offline   Reply With Quote
Old 05-18-2014, 07:42 PM   #6
fiddlybits
fiddlybits's Avatar
I had the same problem and had overhauled the carb and repeatedly checked the specs, especially the float. It would leak fuel and slow/stall during braking.
Finally had my fill so I clamped a rod in the vise, taped a ball jar to it, plopped the top half of the carb on top of the jar and used a clamp to secure it. Added a fuel hose that feeds from a small container and I was all set to SEE the actual fuel level.
Found out 2 things.
1. The fuel level was LOW, which was actually the reason for the slower idle and occasional stall when stopping. A thinner gasket fixed the level.
2. The float valve was not leaking but the valve gasket was leaking. In other words, the valve was closing properly but fuel was seeping by the threads and gasket. A little formagasket #2 and the carb functions
fiddlybits is offline   Reply With Quote
Old 05-18-2014, 07:48 PM   #7
glenn in camino
glenn in camino's Avatar
You have an air leak. Most likely your throttle shaft. The fix is bushings in the upper part of the carburetor where the throttle shaft goes through. Most suppliers sell the bushings or go to a hobby shop and get some brass tubing in the right size.
Old 05-18-2014, 10:04 PM   #8
700rpm
700rpm's Avatar
Lee, make sure your float is at the correct level and that your main and cap jets are at the same height in the throat, and their tips are above the fuel level in the bowl. Dave Adair has the jet flow tester, and you could use that to check all your jets. There's a good booklet with that to show you how it all relates.
Ray Horton, Portland, OR
Old 05-18-2014, 10:27 PM   #9
Mike V. Florida
Mike V. Florida's Avatar
Found out 2 things.
They also sell a fuel level gauge that mounts to the bottom of the carb to see the actual level of the fuel.
Or
Old 05-19-2014, 06:40 AM   #10
fiddlybits
fiddlybits's Avatar
Or
Hey, that's pretty cool and would have been a simpler solution for item 1, the actual fuel level. It also would allow a check with the carb still on the engine.
I guess I'm glad I did not know about it and used the clear glass ball jar as it allowed me to see what was going on inside and see that the fuel was leaking in "above" the float valve.
I think I might put one together for my troubleshooting box.
(I see someone comes from the same school of "so simple it is genius" as I did...using a stiff wire inside a flexible host to keep the hose where you want it. I always use stainless safety wire.)
Old 05-19-2014, 06:44 AM   #11
Mitch//pa
the second photo Mike V shows is a much improved tester sold from renners corner
