Old 04-29-2014, 10:47 PM   #1
larry/Texas
Default 6 volt alternator
I have purchased a 6 volt single wire alternator to install on my '33 with a '38 engine. I do not know if it is negative or positive ground. How do I verify so that I do not have a problem when I try to start the engine. Battery is currently six volt positive ground. I have been told that not changing a 12 volt system battery to negative ground will fry the wiring so as you can see I want to be careful and do it right the first time.
Thanks for your help.
larry/Texas
larry/Texas is offline   Reply With Quote
Old 04-30-2014, 02:40 AM   #2
mike42
mike42's Avatar
Default Re: 6 volt alternator
Hey Larry.....
I had this done a couple years ago and all that I can remeber is that he got rid of the voltage reg and he made it negative ground, but can't remeber everything he did ! I do know that it sure cleaned up all the wiring with the single wire set up and it really works great ! If you don't get an answer I check with him when I get back home friday, but I'm sure someone here will help you.
Mike
mike42 is offline   Reply With Quote
