Old 03-31-2014, 02:54 PM   #1
marc hildebrant
marc hildebrant's Avatar
Default How to Install Fan Belt
Group,
A chunk came off my fan belt and I'm trying to replace it. I'm having a lot of trouble getting the belt around the engine pulley.
The car has a 6 Volt Alternator and came with a belt # 42-6324. I do not know the brand.
The only way that I could remove the belt from the engine pulley was to put the part with the "chunk" removed around the engine pulley. That gave me enough clearance to remove the belt.
Is there a "skinny" belt that I should use ? The old one fit the pulleys nice and worked fine.
There seems to be little clearance under the engine pulley for a belt ?
Marc
marc hildebrant is offline   Reply With Quote
Old 03-31-2014, 03:06 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: How to Install Fan Belt
Sounds like engine mount problem. Does the crank block line up with the crank nut allowing the use of the hand crank to spin the engine?
Old 03-31-2014, 03:13 PM   #3
Bill Lee/Virginia
I purchased a belt that was 1 inch longer and it fits like a glove. I do not have the belt stock number since it was several years ago. Try it. Luck.
Bill Lee/Virginia Peninsula
Bill Lee/Virginia is offline   Reply With Quote
Old 03-31-2014, 03:38 PM   #4
CarlG
CarlG's Avatar
If the belt won't go around the crank pulley, jack the engine up slightly and it will slip right in. Just be sure to put a block of wood between the pan and your jack.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-31-2014, 03:41 PM   #5
johnbuckley
johnbuckley's Avatar
spot on Carl
Old 03-31-2014, 04:10 PM   #6
JBill
Maybe this is just assumed, but I think it would be a good idea to also slightly loosen the single bold holding the front motor mount in the crossmember.
JBill is offline   Reply With Quote
Old 03-31-2014, 04:24 PM   #7
Fred K-OR
Fred K-OR's Avatar
The above comments sounds like what I have to do also to replace my huckster belt. You may want to put something under your front motor mount to get it to sit a little higher so if you break down on the road sometime, you could replace it a little easer. Just make sure your crank will fit in pulley.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 03-31-2014, 04:35 PM   #8
marc hildebrant
Folks,
Thanks for the comments. Currently, the crank fits very well into the engine pulley.
If I raise the motor slightly, do I need to do anything with the front bolt setting ?
Marc
Old 03-31-2014, 04:58 PM   #9
CarlG
CarlG's Avatar
There is usually enough spring action there to lift it up the 1/8 or so needed to clear the belt.
Alaskan A's
Old 03-31-2014, 06:10 PM   #10
Duffy1
Depending on how close it is to going around the pulley . Mine was close so I stretched the belt using my floor jack. If it is close to going on you might want to give this a try before doing any thing else.
Duffy1 is offline   Reply With Quote
Old 03-31-2014, 06:18 PM   #11
Fred K-OR
Fred K-OR's Avatar
Do you maybe have some old dirt or something on your front cross member under the pulley that you could clean off also and get more clearance?
Fred Kroon
1929 Std Coupe
1929 Huckster
Old 03-31-2014, 07:51 PM   #12
Mitch//pa
if the front castellation nut is drawn down to tight that can be the difference. the front motor mount is supposed to float on the springs..
Old 03-31-2014, 08:51 PM   #13
marc hildebrant
Mitch,
How should the nut be set ?
Marc
Old 03-31-2014, 08:53 PM   #14
Mitch//pa
Originally Posted by marc hildebrant View Post
Mitch,
Marc
i set it just enough to get the cotter pin in.
Old 03-31-2014, 09:17 PM   #15
Purdy Swoft
Purdy Swoft's Avatar
I agree with Mitch!!! I only tighten the castellated nut enough to just get the cotter pin through the hole. If the nut is tightened more it will also cause vibration.
Old 03-31-2014, 09:24 PM   #16
Bruce Adams
Bruce Adams's Avatar
If its CLOSE, then make a garrot from a string with a couple of loops (Bowline knots) on each end, put it through the belt and pull it to length to go over the alternator's pulley.
Bruce Adams is offline   Reply With Quote
Old 03-31-2014, 09:32 PM   #17
marc hildebrant
With regard to lifting the motor with a floor jack/wood on the oil pan...
Can the pan support the motor without crumbling ?
Marc
Old 03-31-2014, 09:41 PM   #18
Purdy Swoft
Yes, you won't have to jack it up that much. I would also loosen the rear motor mount bolts to the engine, This will take strain off the flywheel housing.
Old 03-31-2014, 10:41 PM   #19
pat in Santa Cruz
pat in Santa Cruz's Avatar
I strongly agree with this suggestion. You do not want to crack the flywheel housing.
pat in Santa Cruz is offline   Reply With Quote
Old 04-01-2014, 08:24 AM   #20
1931 flamingo
1931 flamingo's Avatar
You could also try starting the belt onto the crank pulley and then hand crank it to pull the belt on.
Paul in CT
