Old 03-27-2014, 04:38 PM   #1
rrhorton
Default Window regulator arm roller query
I installed new glass in my '31 coupe and the existing regulators (3 hole) seem to work OK but the roller on the end of the arm that slides in the window glass lower fitting channel binds up. Is this roller supposed to roll against the channel or does it just slide forward and rearward as the arm moves up and down. Seems it would wear considerably if fixed and I cannot get mine to rotate. It is riveted to the arm.
rrhorton is offline   Reply With Quote
Old 03-27-2014, 05:16 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Window regulator arm roller query
The arms I've worked with have what looks like a roller, but it's actually fixed tight to the arm. I put grease in the slides and that part works well. I also grease the gear teeth and any other moving parts.
Sometimes the felt channels are too tight and cause the binding.
