Old 03-05-2014, 10:35 PM   #1
CBoz
CBoz's Avatar
Default Reproduction cloth heater hose?
Hello -- Does anyone reproduce the cloth heater hose used on the old style heat exchange systems (see pic below)? I know they don't make the asbestos hoses anymore, but wondering if there are substitutes available.
CBoz is offline   Reply With Quote
Old 03-05-2014, 10:45 PM   #2
alan
Default Re: Reproduction cloth heater hose?
no sure but I have seen others use the "choke stove" tubing for this application. last time I checked local Carquest had some on a rack in the middle of the store
alan is offline   Reply With Quote
Old 03-05-2014, 10:47 PM   #3
PeterC
PeterC's Avatar
don't have the answer for you but I must say that heater configuaration would scare the heck our of me fearing exhaust leakage even new!
PeterC is offline   Reply With Quote
Old 03-06-2014, 02:39 AM   #4
ford38v8
ford38v8's Avatar
I saw a great installation on the V8 Club Concourse a few years ago! The owner proudly told me that his hose was manufactured specifically for service in small planes. It wasn't asbestos, of course, but sure looked good. Now you need a pilot to run down the info on where to get it.
Alan
ford38v8 is online now   Reply With Quote
Old 03-06-2014, 06:39 AM   #5
Vic Piano
Vic Piano's Avatar
Cecil, check with some of the LZ parts places, I have been looking for several parts to complete the hot air heater in our '39 LZ and I think someone in the south east is re-popping the "hose" out of fiberglass... Sorry I can't remember who it was, if it comes back to me, I'll let you know.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 03-06-2014, 09:02 AM   #6
Kube
Kube's Avatar
Old fire hose, the type you see in glass enclosures is very similar in appearance as well. I got some when they tore down an old building nearby many years ago.
Is that the last piece you need for your system?
Old 03-06-2014, 02:58 PM   #7
CBoz
CBoz's Avatar
Thanks for the ideas. Got my system working just fine, but the material I used to fabricate a hose has torn (too rigid) and I need to get something more suitable. PS -- system generates lots of heat; I suspect if it ever did develop a leak I'd smell it pretty quickly since these cars don't burn that cleanly.
Old 03-10-2014, 09:17 AM   #8
BOB 40
Yes. I found high temperature material at McMaster-Carr. Part #8851k33. I used the fabric and it worked great. Had to find high temperature thread to sew together. Neighbor is a fire fighter and borrowed the thread from him.
BOB 40 is offline   Reply With Quote
Old 03-10-2014, 11:04 AM   #9
Fibber Mcgee
Fibber Mcgee's Avatar
Same idea used on millions of VWs and I don't remember people dropping dead from exhaust fumes then so it must not be to bad. I had one in a 71 bug and it worked great for the rear seat passengers.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. "
Fibber Mcgee is offline   Reply With Quote
Old 03-10-2014, 01:23 PM   #10
Chris in MA
Chris in MA's Avatar
These folks have what you are looking for.
http://www.hotair4fords.com/Home_______.html
Chris
Chris in MA is offline   Reply With Quote
Old 03-10-2014, 06:25 PM   #11
rotorwrench
rotorwrench's Avatar
Aero Duct can be purchased through Aircraft Spruce and Specialy Co. It comes in all sorts of fractional sizes and in two material types. The black color is a nitrile coated fabric and the red color is high temp silicon coated fabric. There are single wall wire reinforced type and double wall with the wire reinforcement between the two layers. Aircraft use the stuff for heater, defroster, and carburetor heat ducting plus air intake for cooling and engine air supply.
Here is the link: http://www.aircraftspruce.com/search...php?s=aeroduct
