Old 02-24-2014, 08:03 PM   #1
tinmanlsu
tinmanlsu's Avatar
Default Grease Hood Hinge
Working on my hood. What do you guys use to grease the hood hinges? Thanks as always!
tinmanlsu is offline   Reply With Quote
Old 02-24-2014, 08:27 PM   #2
700rpm
700rpm's Avatar
Default Re: Grease Hood Hinge
I oil mine.
Ray Horton, Portland, OR
Old 02-24-2014, 08:41 PM   #3
glenn in camino
glenn in camino's Avatar
Mine get sprayed with WD40 when I clean the underside.
Old 02-24-2014, 09:31 PM   #4
johnsor
A drop or two at each joint. Work hinge a few times. Wipe off any excess.
johnsor is offline   Reply With Quote
Old 02-24-2014, 11:18 PM   #5
Mike V. Florida
Mike V. Florida's Avatar
Ditto
Old 02-25-2014, 01:50 AM   #6
karasmer
I have been wondering that also especially during restoration. If you just put a few drops of oil on it when it's installed there really is no way that the oil can lubricate it thoroughly but if you pull the hood rods lube and re-install your good to go. Question is what would be the best lube to put on the rods before re-installation?
karasmer is offline   Reply With Quote
Old 02-25-2014, 02:31 AM   #7
Mike V. Florida
What makes you say that? A drop of oil get all the parts of a hinge either at home or in your car. Why not the hinge of the hood?
Old 02-25-2014, 03:43 AM   #8
dave in australia
I use teflon spray.
dave in australia is offline   Reply With Quote
Old 02-25-2014, 04:38 AM   #9
Roadster62
Roadster62's Avatar
AFTER YOU PAINT IT! Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical.
Roadster62 is offline   Reply With Quote
Old 02-25-2014, 08:16 AM   #10
Keith True
Keith True's Avatar
Many years ago I got a bunch of teflon rod pieces from a friend that ran screw machines.I made maybe a half dozen center hood rods out of them,and I don't think I've ever looked at one of them since.They're quiet,smooth,and no rust works it's way out of the hinges with use.I still used the metal rods in the hood side joints,as I never found any scrap teflon rods that small.I don't believe I've ever lubed one after it was installed either.
Old 02-25-2014, 11:50 AM   #11
Purdy Swoft
Purdy Swoft's Avatar
The first thing that I do is replace the steel hood hinge rods with stainless steel. Most vendor have them, they don't rust and need no oil.
Old 02-25-2014, 04:44 PM   #12
Mad Mac
Yeah, what Purdy said.
Mad Mac is offline   Reply With Quote
Old 02-26-2014, 10:22 PM   #13
karasmer
With door hinges the oil draws down with use and gravity, seems like a lot of use to get the oil to travel sideways an inch, I suppose if the hood is removed you can oil the hinges on the backside seam.
Old 02-27-2014, 07:34 AM   #14
Rock Hornbuckle
Rock Hornbuckle's Avatar
I use graphite it doesn't collect dust like oil does.
'31 Fordor Deluxe 2W Briggs 170-B / blackwalls
'41 Fordor Deluxe / 2-duece flattie
'66 1/2 Dodge Charger
'14 100th Anniversary Challenger Limited Edition.
Semper Fidelis
Rock Hornbuckle is offline   Reply With Quote
Old 02-27-2014, 11:38 AM   #15
Russ/40
Russ/40's Avatar
I found the vendor stainless rods to be too tight a fit. Just can't get them in.
Old 02-27-2014, 02:52 PM   #16
hardtimes
hardtimes's Avatar
Hey Russ,
Yeah, like Purdy, I've used same stainless rods for years..very nice to have NO rust, eh ! To 'encourage' them to go in and fit tight ...w/o squeaks,etc...I use graphite. I use both the dry powered type and the spray type with very satisfactory results. Another good benefit is that they do not gather/attract dust/dirt.
BTW..do not get mine from vendors, perse, but from builder discount/supply places. They also have rods in diff metals (brass is good too).
