Old 02-24-2014, 03:28 PM   #1
johnbuckley
johnbuckley's Avatar
Default Model B distributor (or alternative ) needed.
Friend of mine here in UK has a B engine but only the housing of the distributor-no innards. Is there anywhere Stateside that sells complete B dissys or complete internals? Have any forumists got an alternative suggestion eg possibly an A dissy with an auto advance mechanism?? All suggestions welcome.
Old 02-24-2014, 03:32 PM   #2
Charlie Stephens
Default Re: Model B distributor (or alternative ) needed.
Try Renner's Corner, rennerscorner.com, (734) 428-8424. Don't waste your time with Mickey Mouse short cuts. Be sure to weigh the cost of shipping your core body versus just paying the core charge.
Charlie Stephens
Old 02-24-2014, 07:43 PM   #3
Duffy1
Berts
Duffy1 is offline   Reply With Quote
Old 02-24-2014, 07:51 PM   #4
Joe K
Joe K's Avatar
A centrifugal rotors exist - but Ebay puts them quite expensive at $300 range. Likely your best bet to pick up another B distributor. Usually less than $100 on ebay for a good one. (complete)
The above recommendations good too.
Joe K
Shudda kept the horse.
Joe K is online now   Reply With Quote
Old 02-24-2014, 08:24 PM   #5
bettlesr
bettlesr's Avatar
FS Ignitions sell the complete shaft assembly for $159
http://www.fsignitions.com/ROTATING_SHAFT_ASSEMBLY.html
1965 Lotus Elan S2
1930 Model A Sport Coupe
bettlesr is offline   Reply With Quote
Old 02-24-2014, 08:35 PM   #6
TinCup
TinCup's Avatar
The folks at Renners are top notch. They know that B distributor inside and out. They sell complete rebuild kits or just parts.
TinCup is offline   Reply With Quote
Old 02-24-2014, 10:05 PM   #7
Charlie Stephens
Originally Posted by Duffy1 View Post
Berts
Bert's ((800) 321-1931) is probably one of the best Model A suppliers out there from all that I have heard and you should definitely call them. I recommended Renner's Corner ((734) 428-8424) since they specialize in Model B parts and that is what you are looking to find. Just a tip for the Model B distributer. I don't think anyone makes condensers and NOS ones are just too old. Get the best Model A condenser you can find (I think it will be the one that A&L sells, (860) 693-2620). Elongate the hole in the tab on the end so it can be installed in the Model B distributer. Make a short pig tail and attach it to the end of the condenser and run it to the distributer where the original Model B condenser attached.
Charlie Stephens
Old 02-24-2014, 10:43 PM   #8
Duffy1
There was a post on here about 6 months ago that talked about model B dist. running retarded when they first came out thus causing the B engine to run hot .
Old 02-25-2014, 04:43 AM   #9
juke joint johnny
juke joint johnny's Avatar
I have a late English Model B one available , Looks like the one on the Ford 10 or Anglia engine, it uses normal spark plug wires .and has a weighted advance .
Let me know if you want it
John Cochran
juke joint johnny is offline   Reply With Quote
Old 02-25-2014, 08:21 AM   #10
brokenspoke
Bubbas ignition has a new one
brokenspoke is offline   Reply With Quote
Old 02-25-2014, 08:58 AM   #11
johnbuckley
Thanks everyone. Obviously plenty of places to start searching
