Old 02-13-2014, 08:46 AM   #1
marc silva
marc silva's Avatar
Default Acetone to atf mixing ratio
Does anyone have the mixing ratio of acetone to ATF I think it was to loosen rusty bolts? It was in a recent copy of the Restorer but I am not at home to look it up. Thanks
marc silva is offline   Reply With Quote
Old 02-13-2014, 08:50 AM   #2
RockHillWill
RockHillWill's Avatar
Default Re: Acetone to atf mixing ratio
I cannot speak to what others are doing, but 50-50 has worked very well for me.
Uncle Bud says "too soon old, too late smart!"
RockHillWill is offline   Reply With Quote
Old 02-13-2014, 09:16 AM   #3
marc silva
marc silva's Avatar
Thanks. Do you think that it will work on some head studs? They look pretty rusted up and I have had to drill some out before but I really don't like doing that if I don't have to. I am re-building an engine and am in no hurry so I have time to let it soak in.
Old 02-13-2014, 09:44 AM   #4
Ron/IA
I too, have used the 50-50 ratio. One thing is the acetone will evaporate out of the ATF; so you need to replenish it.
One thing that helps is to take some plumbers putty and make a little dam around each stud. It keeps the solution concentrated around the stud. Then just keep adding if needed.
Ron/IA
1929 Fordor Steelback
Hawk A Model A Ford Club
http://hawkamodelaclub.org/
Ron/IA is offline   Reply With Quote
Old 02-13-2014, 11:53 AM   #5
LopezCarguy
LopezCarguy's Avatar
50/50 works just fine...does work better than anything else I've tried including PB Blaster...Dick
LopezCarguy is offline   Reply With Quote
Old 02-13-2014, 12:05 PM   #6
Tiny
Tiny's Avatar
50/50 works great. Make the well like Ron said and just let it soak. Forget about it for a week or two. Just keep replenishing the mix so it always wet. Don't get impatient. Time is your friend.
Good luck
Blackwall Panthers
Nor Cal chapter
Tiny is offline   Reply With Quote
Old 02-13-2014, 12:06 PM   #7
Brian in Wheeling
Brian in Wheeling's Avatar
When I recently tried this I mixed by eyeball, about 50/50 Acetone and some old, unused ATF I had in a quart bottle. Shook it up and it looked milky pinkish. When set back down, the two began to separate! Is this normal to have to shake up before you use it? I stored it in a glass bottle with a screw top, so no evaporation. I've had good luck with a product called Kano Kroil and have been using it for over a decade.
Brian W.
Brian in Wheeling is offline   Reply With Quote
Old 02-13-2014, 12:31 PM   #8
fiddlybits
fiddlybits's Avatar
I find the a much better ratio is 1:1.
fiddlybits is offline   Reply With Quote
Old 02-13-2014, 12:51 PM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
I also mix it 50/50 and have to shake it up before each use.
Another method has been used with success, and that is to heat the stud and as it cools melt some wax against it, so it will wick down into the threads.
Old 02-13-2014, 01:10 PM   #10
ford3
after soaking the bolt hit the head of it several times to send a shock down the bolt to loosen the rust , on head nuts take 2 hammers, good sizes ball peens, hold one hammer agaist the nut as a back up while you smack the other side, do that all the way the nut, what this does is distort the nut a little and breaks the rust bond between the nut and stud, use the 50-50 mix and smack the nuts several times a day if you have time
ford3 is offline   Reply With Quote
Old 02-13-2014, 02:28 PM   #11
BudP
BudP's Avatar
I have used 50-50 acetone-ATP on head studs, manifold studs and water pump studs. Works better than Kroil in my experience. Haven't broken a stud yet (knock on wood). I heat the stud, apply the mixture, put a block of wood on top of the stud, whack the wood, try to turn the stud in either direction, and repeat the process the next day, the next day, etc., until I get a little movement. Once I get movement, I "own" that stud. Good thing I'm not getting paid for my time!
BudP is offline   Reply With Quote
Old 02-13-2014, 02:38 PM   #12
marc hildebrant
marc hildebrant's Avatar
Note: "Ed's Red" is a mixture of equal parts acetone, kerosene, ATF, and paint thinner.
Used to clean gun parts and helps with stuck bolts.
Marc
marc hildebrant is offline   Reply With Quote
Old 02-13-2014, 04:08 PM   #13
nhusa
nhusa's Avatar
I use a 75:75 mixture - It is significantly better than 1:1 or 50-50
But the 25-25-25-25 mixture sounds interesting
Seriously -
In practice any oil based fluid mixture with a low surface tension will work because it will attempt to force it's way into any creavice it can find. Mixing a bit more acetone with the ATF might help in some cases because it wil stay wetter longer and the surface tension may be a bit lower.
The kerosene, acetone, paint thinner mix reminds me of how kerosene will seemingly soak into the surface of cast iron and it takes a bit longer to evaporate than acetone etc. Heat can certainly help because it lowers the viscosity of the oil and the expansion - contraction will help open the space up a bit.
Additionally the keeping ot wet tricks using Plumbers putty etc. make a lot of sense!
nhusa is offline   Reply With Quote
Old 02-13-2014, 04:20 PM   #14
Ron W
Ron W's Avatar
I've heard that 3 to 3 also works well! Ron W
Ron W is offline   Reply With Quote
Old 02-13-2014, 06:20 PM   #15
nhusa
nhusa's Avatar
Ron that's a skimpy mixture - That's why I prefer 75 -75
Old 02-13-2014, 09:00 PM   #16
Ron W
Ron W's Avatar
It's for use on small bolts and you don't have too much left over . Ron W
Old 02-14-2014, 07:59 AM   #17
nhusa
nhusa's Avatar
Oh now I understand.
When I get stuck, I wait until I am in big trouble before admitting it so I need a lot of stuff.
Old 02-14-2014, 09:16 AM   #18
BillLee/Chandler, TX
BillLee/Chandler, TX's Avatar
Everybody is a
Bill Lee
http://www.CedarCreekAs.org
BillLee/Chandler, TX is offline   Reply With Quote
Old 02-14-2014, 10:40 AM   #19
fiddlybits
fiddlybits's Avatar
Do you guys have a 15/17" wrench and a glass headed ball pean hammer for precision adjustments also?
(Thanks for the chuckles)
Now, seriously.... in this day and age of equality.... the mix must contain an equal amount of ATF and acetone. We must have equality and PC, don'tchaknow...
I have also found that ATF and MEK works just as well. (MEK available by the gallon at ACE Hardware)
Old 02-15-2014, 11:57 PM   #20
karasmer
The object is to get the liquid between the two sufaces, I heard that kroil oil is 50 times thinner than WD-40, now what would be the thinnest as far as viscosity be, plain water is very thick. I use any kind of spray lube laying around with some heat from a map torch and usually always have success removing any rusted parts, still looking for the thinnest liquid on earth though?
karasmer is offline   Reply With Quote
