Old 01-20-2014, 08:52 PM   #1
dongas30
Default Alternate Radiator Choices for Flatheads?
Is there a way to use a radiator with a single inlet and outlet instead of the dual in/out FH radiators? Maybe an early mustang type?
dongas30 is offline   Reply With Quote
Old 01-20-2014, 09:21 PM   #2
Ed Pitts
Ed Pitts's Avatar
Default Re: Alternate Radiator Choices for Flatheads?
I used a 66 Mustang radiator but I added additional outlets. Works fine and keeps the engine cool. Ed
Ed Pitts is offline   Reply With Quote
Old 01-20-2014, 10:13 PM   #3
19Fordy
19Fordy's Avatar
I guess one way you could do that is to design a crossover pipe that feeds both heads. That crossover pipe would have a single inlet hose going to the top of the radiator. You would still have the problem of how to to distribute the water leaving the bottom of the radiator in large enough amounts to get pumped thru the engine in order to keep it cool. Perhaps a high volume electric water pump is part of the solution along with a reverse flow cooling system.
Old 01-20-2014, 10:44 PM   #4
Mike in AZ
Mike in AZ's Avatar
someone does a Chevrolet water pump installation for the flathead.....waterpump from the 409??......here's a link to the HAMB discussion.....Mike
http://www.jalopyjournal.com/forum/s...d.php?t=200778
Mike in AZ is offline   Reply With Quote
Old 01-20-2014, 10:55 PM   #5
Talkwrench
Talkwrench's Avatar
Why ???
Old 01-21-2014, 01:01 AM   #6
Mike B
Originally Posted by Talkwrench View Post
Why ???
Cost would be my guess...
Mike B is offline   Reply With Quote
Old 01-21-2014, 06:37 AM   #7
Vic Piano
Vic Piano's Avatar
I would think it would cost more to make all the necessary modifications to a single inlet/outlet radiator. Why not just have the original style radiator redone or get a new OEM style radiator?
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 01-21-2014, 11:04 AM   #8
gmc1941
gmc1941's Avatar
WHY! BECAUSE. WHY NOT, WHY CAN'T I, I KNOW I CAN, DAM-IT I WANT TO. Maybe I need some help mentally.......
1939 Fordor Deluxe
1939 Ford Coupe Std
1940 Ford pickup
Nothing in life is to be feared; it is only to be understood.
gmc1941 is offline   Reply With Quote
Old 01-21-2014, 11:31 AM   #9
rhpope
Ed,
What model car or truck are you using the Mustang radiator in?
Thanks,
Roger
rhpope is offline   Reply With Quote
Old 01-21-2014, 11:50 AM   #10
dongas30
the car is 1926 roadster and considering placing rad in trunk.
Old 01-21-2014, 01:24 PM   #11
Ed Pitts
Ed Pitts's Avatar
Originally Posted by rhpope View Post
Ed,
Thanks,
Roger
Roger, I'm not using it in a car. Just needed a radiator for my test stand and since I had the Mustang radiator, it was an experiment to see if it would cool the engine. It works fine. Ed
