Old 08-25-2010, 06:50 AM   #1
toms32
Default Modification Model A pitman Arm
Model A Pitman Arm - I came accross an article about shortening a model A pitman arm to ease driving. I have an problem about welding critical steering components however that said has someone else done this or is there a place I can purchase this modified part. This in my opinion would have to be done by a certified welder and that I am not. Thanks Tom
toms32 is offline   Reply With Quote
Old 08-25-2010, 07:18 AM   #2
Keith True
Keith True's Avatar
Default Re: Modification Model A pitman Arm
They are available new now from the big vendors.I have always welded my own,but for customers I buy them.For the time I put into them I can buy two of the new ones.The idea of welded steering parts scares some people,but it has been in use for years.Trucks with hydraulic steering have the piston eyes welded onto both ends,some with an idler arm/equalizer have a two hole plate welded onto the forged arm,there was a weld-on kit for old VW's that replaced the end on the two hole pitman arm when the holes got wallowed out.If you ever drove route 101 through N.H.in the 60's and early 70's you met dozens of B model Macks with shortened pitman arms.Zapora hauled oil and gas around the clock and the mechanics shortened the arms on most of those trucks.I have bought the new arms from either Brattons,Snyders,or Mikes.I think they were only around 30 bucks,and I spend two hours cutting,fitting,welding,and grinding to do one.I do tend to get a little fussy when doing one.Somebody posted a picture of a homemade broken one,it looks as if it was done by a monkey with a harbor freight welder.It was a good example of stupidity,not of a good welder.He had bought the car like that.
Old 08-25-2010, 07:56 AM   #3
Ron/IA
Toms32 - Keith is right on the money. Before today's vendors made available a completely made non-welded shortened pitman arm, it just isn't worth the effort doing it yourself.
A few years ago before availability, I cut and welded one using the Z-design. As Keith stated; time consuming. It is very strong and I have complete faith in it, but I won't do it anymore.
I recommend buying one from the vendors.
Ron/IA
1929 Fordor Steelback
Hawk A Model A Ford Club
http://hawkamodelaclub.org/
Ron/IA is offline   Reply With Quote
Old 08-25-2010, 09:08 AM   #4
V4F
V4F's Avatar
yes just buy one . safer ................. steve
V4f
V4F is offline   Reply With Quote
Old 08-25-2010, 09:49 AM   #5
Wick
Wick's Avatar
Had to use one on my Speedster aftering lowering the frontend.
Wick is offline   Reply With Quote
Old 08-25-2010, 10:01 AM   #6
Glenn C.
Glenn C.'s Avatar
Shortened pitman arm also helps to keep the drag link away from the tie-rod. Buy a new one. Play it safe.
Glenn C. is offline   Reply With Quote
Old 08-25-2010, 11:45 AM   #7
Dick Deegan
Dick Deegan's Avatar
I bought mine from Snyder's at a ver yreasonable price.
Dick Deegan is offline   Reply With Quote
Old 08-25-2010, 12:17 PM   #8
Purdy Swoft
Purdy Swoft's Avatar
I get mine from Wiley Higgins in Cummin Georgia. They really help and Wiley does a wonderful job.
Old 08-25-2010, 01:44 PM   #9
2manycars
2manycars's Avatar
I shortened a few for my cars several years ago. I made the cut in a Z, chamfered it to a V on all edges to be welded, and welded both sides with multiple passes, finishing with an annealing bead in the center. That is how I was taught at Electric Boat Shipyard welding school many years ago when I welded on nuclear submarines. It is time consuming, and I would not do one for a customer, because if the car was in a crash for any reason at all, and it was mentioned I had welded the arm, the ambulance chasing lawyers would have me in a corner. It is great they are now being made, and I understand they are forgings, like original. I have not seen one, but have heard good reports.
2manycars is offline   Reply With Quote
Old 09-11-2010, 06:56 PM   #10
toms32
Many thanks to all who responded on this tech issue. Tom
Old 09-11-2010, 07:10 PM   #11
b ramsey
i just did mine today, cut the extra tapered hole off my passenger side spindle ('40) and used it on the pitman arm so i can make a new drag link using modern rod ends. welding these is cake.
b ramsey is offline   Reply With Quote
Old 09-11-2010, 08:01 PM   #12
BCCHOPIT
BCCHOPIT's Avatar
Are the new ones a cast part? Any one have a link
thanks Bill
BCCHOPIT is offline   Reply With Quote
Old 09-11-2010, 08:12 PM   #13
BCCHOPIT
BCCHOPIT's Avatar
found it....
All new forged one-piece pitman arm. This arm is 1.5" shorter for easier steering. Made from SAE 4130 chrome moly steel.
$35.50 that is a great price must be made in china
I think I will still weld my own I trust welded old ford forged steel more the some new china crap
just my 2 cents
later Bill
Old 09-12-2010, 10:43 AM   #14
Pa Joe
Pa Joe's Avatar
I called three vendors for one, everyone was out of them . I'm on a waiting list at Snyders. JK
Pa Joe is offline   Reply With Quote
Old 09-12-2010, 10:53 AM   #15
Peter J
Peter J's Avatar
Me too with Snyder's. I hear that it widens the turning circle somewhat but sounds like a good trade off.
Peter J is offline   Reply With Quote
Old 09-12-2010, 12:23 PM   #16
Keith True
Keith True's Avatar
In theory it may open up the turning radius some,or maybe with a 7 tooth steering box,but I can't speak for that as I never tried one.I can tell you that with a 2 tooth box the spindle arms hit the stops with both the long and short arms.Zero radius change on every one I have done.
Old 09-15-2010, 12:24 PM   #17
snookcapt
Mike's has new ones, the only way.
snookcapt is offline   Reply With Quote
Old 09-15-2010, 01:57 PM   #18
Kirby1374
Kirby1374's Avatar
so a shortened arm makes it easier to steer at low speeds (parking etc.) but what about out on the highway? does it change the feel? like wandering etc.?
Kirby1374 is offline   Reply With Quote
Old 01-30-2016, 07:24 PM   #19
fiftyv8
Was there ever an answer to the last post on here?
Especially since so many of us run O/D's these days and better brakes...
fiftyv8 is offline   Reply With Quote
Old 01-30-2016, 07:30 PM   #20
fiftyv8
I note the Snyder's advert say LHD only!!!
What would be required to use this on a RHD vehicle.
Wouldn't they be the same???
Model A Shortened Pitman Arm
One and one-half inches shorter than the stock pitman arm, which makes for easier steering. Made of SAE4130 chrome moly steel. Left hand drive only.
