Old 11-15-2013, 10:32 AM   #61
BangerMatt
BangerMatt's Avatar
Default Re: Speedster Kit
Originally Posted by Bill O'Brien View Post
How about some more pics of Speedsters!
Speedsters are fun, here are some pictures of a couple that my father and I have built together. The first was a partially built Rootlieb kit where the folks building it "lost some parts". We took it apart and redid it the way we wanted to, using a '40 Buick hood for the tail.
The second is the red one, built from the ground up using a "hot rod cast-off" chassis using a '41 Ford hood for the tail.
BangerMatt is offline   Reply With Quote
Old 11-15-2013, 02:00 PM   #62
George D
George D's Avatar
Just wondering, what goes between the plywood deck and the frame on these kits? Is there some form of crossmembers or spacers of some sort?
George D is offline   Reply With Quote
Old 11-15-2013, 03:10 PM   #63
BangerMatt
BangerMatt's Avatar
The kit that I disassembled just had something like a welting material in between. Nothing substantial. The rear plywood had been cut to allow the hump of the rear crossmember through.
Old 11-15-2013, 03:34 PM   #64
Skrain
Skrain's Avatar
A question for anyone with a Rootlieb speedster...how large are the seat buckets?
"They can make me grow older, but they CAN'T make me grow up!"
Skrain is offline   Reply With Quote
Old 11-15-2013, 03:37 PM   #65
George D
George D's Avatar
Thanks. Those pictures on the dirt track are cool!
Old 11-15-2013, 03:41 PM   #66
Sparky
Sparky's Avatar
You mean width? I'll measure mine for you when I get home.
Sparky is offline   Reply With Quote
Old 11-15-2013, 03:52 PM   #67
Skrain
Skrain's Avatar
Thanks. I need to know if MY bucket will fit in one, or if I will have to come up with a bench seat like Mike has...
Old 11-15-2013, 05:57 PM   #68
Sparky
Sparky's Avatar
The shell is 20" wide and I have an inch of upholstery on each side, so it's about 18" on mine.
Old 11-15-2013, 07:03 PM   #69
Skrain
Skrain's Avatar
Looks like it's going to be a bench seat for me!
Old 11-15-2013, 07:25 PM   #70
howie123
howie123's Avatar
Q Golden, Thanks for the comments. I am attaching a few more pictures. Howie.
howie123 is offline   Reply With Quote
Old 11-15-2013, 07:58 PM   #71
Ross/Kzoo
Ross/Kzoo's Avatar
I was in pretty much the same boat until I came up with this:
http://www.ebay.com/itm/Model-T-Ford...item258326d286
I just noticed the ePay price is $55 more than their website price.
I've had mine for about 6 years and quite a few miles. Have some good foam in the upholstery and is comfortable. I'm 6'2" and 230#.
Ross/Kzoo is offline   Reply With Quote
Old 11-15-2013, 07:58 PM   #72
modelAsteve
modelAsteve's Avatar
You really don't want a bench seat! You will slide around and not enjoy the speedster. Just start with some metal and wrap it around you and go from there. They are really fun to build!
modelAsteve is offline   Reply With Quote
Old 11-15-2013, 08:32 PM   #73
Sparky
Sparky's Avatar
Hey Howie, is that Ford logo on the gas tank a decal or a custom job?
Old 11-15-2013, 11:02 PM   #74
QGolden
QGolden's Avatar
Thanks for the inspiration! Where does your Starter Rod go? It looks lengthened and is a a high angle.
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain.
It is the very things that we think we know, that keep us from learning what we should know.- Unknown
QGolden is offline   Reply With Quote
Old 11-16-2013, 07:56 PM   #75
howie123
howie123's Avatar
The Ford logo was hand painted by the pinstriper. He did a beautiful job. I kept the choke and starter rods as close to original angle as I could determine. They run through the firewall with steel guide plates. The starter rod is just round stock threaded to screw into the starter switch with a wooden handle on top. With the firewall set back 3 inches, the starter rod enters behind the dash. I shortened a reproduction choke rod and made a longer sleeve using large diameter brake line. The GAV/choke rod also enters behind the dash. Operating the starter and choke at the same time is a stretch but I have long arms. I used a reproduction starter pedal as a gas pedal. I welded an extension to the stock throttle linkage and made a swivel for the pedal to screw into. I found all the final details to be the most enjoyable part of the project. This summer I added turn signals using a vintage turn signal unit and motorcycle signal lights mounted with custom made brackets. Thanks again for all the positive comments. Howie
Old 11-17-2013, 04:16 AM   #76
Brian LI
Brian LI's Avatar
Latimore Valley fairgrounds in York Springs PA. Home of the Jalopy Showdown every May. A good time for sure.
Lots of info on it over on the HAMB.
Brian LI is offline   Reply With Quote
Old 11-20-2013, 05:14 PM   #77
48fordnut
48fordnut's Avatar
Ok speedster fans, I have started on my 31 frame. It is almost bare and needs blasting.
Going on vacation and will try to post some pics in Dec when I get closer.Will be using ft brakes only,don't know about wheels yet. I like the look of wide 5 for the rear. Will be reversing the ft spring eyes,possibly a t spring in the rear. May try swapping my 31 rad and grill for 28/9
How thick is the plywood base? How thick is the metal for the body ?Why do you need to move the steering back? Not a problem though.
I have a friend that is very good at fabrication work,and he is going to help.
48fordnut is offline   Reply With Quote
Old 11-20-2013, 07:23 PM   #78
howie123
howie123's Avatar
The deck for the Rootleib kit is made of 2 layers of 3/4 inch plywood. The top layer is one large piece, the bottom layer is smaller pieces placed for reinforcement. I am not sure of the sheet metal thickness. It is quite easily formed over the cowl and around the seats. In the kit, the hood is about 3 inches longer than stock and so the firewall is about 3 inches further back. That requires moving the steering column back. It also means changing the choke rod, starter rod, throttle and spark linkage. If you are not using the kit, you can do whatever you'd like. I saw a picture of a speedster built using a stock cowl and fenders and it looked really nice. You can be as creative as you want and that is the fun part. Howie
Old 11-20-2013, 08:34 PM   #79
48fordnut
48fordnut's Avatar
I will be copying the kit .Lowering the steering is not a problem.
Have been doing some research on my fathers side. My GGfather had a body shop where they built truck bodies, and wagons. It's not a stretch that he built some car bodies. This will be the Jefferson Body Shop Spl, B'ham Al. Would have been est around 1915 I think. I have the st address.Colors will be red /cream,black lettering.
Is there any chance I could see what the bottom panel of ply looks like?
Old 11-20-2013, 10:34 PM   #80
Sparky
Sparky's Avatar
Does this help?
