Old 11-14-2013, 07:32 PM   #1
springerpete
springerpete's Avatar
Default Fuekl gauge reading adjustment
The gauge moves OK but the reading is off because I think the rod that connects the float to the number fitting is bent. When full all I get is a 3/4 reading and it shows between 1/4 and empty with 2-3" of gas still in the tank.
Will bending the rod fix this ? Anyone done this and what is your process ? Be pleased to get some help. Bill
springerpete is offline   Reply With Quote
Old 11-14-2013, 07:41 PM   #2
Steve Miller
Steve Miller's Avatar
Default Re: Fuekl gauge reading adjustment
This might help
https://www.youtube.com/watch?v=ucSV66JVyDc
Steve Miller is offline   Reply With Quote
Old 11-14-2013, 07:43 PM   #3
700rpm
700rpm's Avatar
Just bend the rod. I cut a groove wide enough to get around the rod in a piece of 3/4" flat steel about 1" from one end. I then removed the fire screen, pulled the rod up with a piece of coat hanger, held it firmly against the top of the tank, and gently coaxed the rod into a lower position with the flat steel placed a bit in front of the coat hanger. This is a trial and error procedure, and may take a few tries to get it right.
Ray Horton, Portland, OR
Old 11-14-2013, 07:48 PM   #4
700rpm
700rpm's Avatar
Steve was just a little faster than I was. That video is a good explanation.
Old 11-14-2013, 08:23 PM   #5
whirnot
whirnot's Avatar
Yep, adjusted mine that way, works perfectly.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1931 Coupe
2 Smith Motor Compressors
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 11-15-2013, 07:09 AM   #6
springerpete
Smile Re: Fuekl gauge reading adjustment
OK, gentlemen, I appreciate your suggestions. Supposed to be pretty nice day here today so I'll get the A out of the garage into the sunshine and give it a try. Thanks.
