#21 |
What is the cost of the kit?
I would love to build one of these, and may end up with a spare chassis soon. |
#22 |
Those are Universals; can't answer the wear question because I've put only a hundred miles or so on them so far.
#23 |
#24 |
Thanks Sparky.
I could have checked their site, and called them, but nice to ask here. Hope you dont mind, im currently using your speedster as my wall paper for inspiration. |
#25 |
Thanks, I'm honored!
#26 |
#27 |
#28 | |
![]() Quote:
Thanks in advance for any you can provide! --Dan |
#29 |
Hi Dan,
My filler neck has an extra saddle-shaped piece that fits between the filler itself and the tank. Do you have something like that? I think they are soldered together; I didn't assemble my tank personally. |
#30 | |
![]() Quote:
#31 |
I dropped my speedster 4 inches by using a T rear spring and only leaving in I think about 6 maybe 7 leafs. For a rootlieb kit, this would be plenty sense there is not weight in the back of them. My speedster is a boat tail, that had the 15 gallon gas tank in the very back. It does bottom out when I hit a big enough bump. I haven't gotten to adding shocks yet, but I'm probably going to have to drop the rear end and add a leaf or two in the assembly.
My cars getting the upholstery done right now, so after this Friday I should be able to post pictures of it completely done ![]()
Cowtown A's |
#32 |
Subscribed!
#33 |
Hi there,
I am building a speedster and looking at every component with the view of improving performance and improving handling whilst utilising as much of the original A components as possible A dropped front axle has given me a headache as the tie rod is now too close to the chassis and the front brake shaft supports have needed extending up and made additionally stiffer. At the rear the spring mounts on the diff have been relocated to lower the rear. A quick change centre section on the diff has resulted in an open drive shaft with the radius rods (front and rear) relocated to the chassis rails and an F150 gearbox has slotted in simply using a Macs Speed shop bellhousing. An alloy radiator reduces weight and the petrol tank is at the rear between the chassis rails for lower CofG. Oh yes, the motor is moved back 4" and the wheelbase is 4" longer. All these mods are resulting in the project taking a lot longer than anticipated as I don't have engineering skills. Cheers, Keith |
#34 |
Another option is to work with Jim Husbey @ olympic speedsters. Great guy to work with. The pic is one that I worked with him on last year.
#35 |
#36 |
Here is my home made speedster. I'm a po country boy and couldn't afford the kit. I had a bunch of discarded parts and decided to try and make a purty out of them.
#37 |
beautiful!
"They can make me grow older, but they CAN'T make me grow up!" ![]() |
#38 |
Skrain,
Thank you, we have a lot of fun with this car mike |
#39 |
#40 |
Mine started as speedster, and I decided to fab my body rather than buy one I started with the chassis in my avitar, took 3 springs out of the rear, 2 out of the front, re rolled the front springs to turn the eyes over., and used 17 inch wheels. It sits a few inches lower all around, and has about 3 inches of rake to the front. Admittedly it is morphing into more of a Rod than a speedster though.
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain. It is the very things that we think we know, that keep us from learning what we should know.- Unknown |
