Old 10-29-2013, 04:07 PM   #21
calvin amerson
Default Re: brake lights are on on on
happened to me solved by turning lights off
calvin amerson is offline   Reply With Quote
Old 10-29-2013, 04:55 PM   #22
pick
thanks all for your ideas and particularly for the wiring diagrams. Looks like I have my work cut our for me. Being a widower I'm awaiting my son to stop over and lend me a hand (hard to be at two places under/around the car at one time). Weird thing is that it didn't occur until after I'd driven it a couple of times. I'll keep y'all posted on the results. Again, thanks!
pick is offline   Reply With Quote
Old 10-29-2013, 05:26 PM   #23
CarlG
CarlG's Avatar
Originally Posted by tuneman View Post
Could the battery be hooked up backwards?
Then you'd be sucking the juice out of the bulbs instead of putting it in?
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 11-02-2013, 05:02 PM   #24
pick
fixed ended up being problem at light switch thanks for all the posts
Old 11-02-2013, 05:31 PM   #25
PC/SR
Congratulations on the fix, and thanks for the report.
PC/SR is offline   Reply With Quote
Old 11-02-2013, 08:14 PM   #26
Tom Endy
Tom Endy's Avatar
One of Henry's not so good ideas was to provide power to the brake light switch from the light bale. The bale is a failure prone area with a rats nest of wires inside. Some of the poor quality repo bales on the market make the situation worse.
If you look at the wiring diagram the bale receives its power from a wire from the generator cut-out (or alternator). The wire is attached to a buss inside the bale. Attached to same buss is a wire that runs to the brake light switch. There is really no reason for power to the brake light switch to be routed through the bale.
A better idea is to remove the wire from the bale to the brake light switch and instead run a wire from the fuse holder (or the starter switch connection if you don't have a fuse) direct to the brake light switch.
With this set up there is less chance of losing power to the brake lights and trouble shooting the brake light circuit becomes very simple.
Should you be out on the road and you have a short circuit in any of the wires in the bale and it blows the fuse (or starts a fire if you don't have a fuse) you can disconnect the wire from the generator (alternator) to the bale and eliminate the fault and still have brake lights. If it is daytime you can continue to drive the car safely with functioning brake lights until you are able to trouble shoot the bale.
Tom Endy
