Old 10-16-2013, 11:38 AM   #1
41plym
Default starter switch
I bought a new switch from one of the big vendors and it doesn't line up with the rod. I took off a switch that worked off the spark advance lever so I don't have one to compare it to. Is the angle of the switch wrong or could it be something else?
41plym is offline   Reply With Quote
Old 10-16-2013, 11:46 AM   #2
sjessen
sjessen's Avatar
Default Re: starter switch
I had the same issue.
The switch seems to have the wrong angle
Steve J.
sjessen is offline   Reply With Quote
Old 10-16-2013, 11:51 AM   #3
jrapose
jrapose's Avatar
Could be that the body is mounted to high or to low on the frame.... but those switches have lots of play on the switch side so it would have to be way to high or way to low.... there is a grommet in the hole that goes thru the firewall....could that be mounted wrong ?
Or was the switch made by Vintique ? if it was it is poor quality and probably the problem...nothing they make is any good.
Joel
jrapose is offline   Reply With Quote
Old 10-16-2013, 12:21 PM   #4
Purdy Swoft
Purdy Swoft's Avatar
Early 28 models used a different starter switch.
Old 10-16-2013, 12:53 PM   #5
41plym
I took the grommet out of the fire wall which leaves a big hole and it's still not even close to the right angle. I put an offset in the rod but to make it work but it's not right.
I'm not sure what brand the switch is it's unmarked. The body and motor are mounted in the right spot, I don't believe either has ever been removed.
Old 10-16-2013, 01:23 PM   #6
H. L. Chauvin
Hi 41,
Had exact same problem expressed in an earlier post on about 07/18/2013 after just buying two (2) "new" starter switches.
My old & two (2) new switches were hanging up in the "ON" position whereby the pedal rod could not rise into the "OFF" position -- starter kept rotating while engine was running.
These new switches are hefty & well made; however, the small "circular" metal opening for the threaded female switch rod tube is so tight & small that the switch's threaded female rod tube angle cannot be adjusted.
Think all new ones from Vintique are like that.
Quick Fix:
1. Mount switch on starter & place a 5" high by 6" long piece of vertical cardboard immediately adjacent to the engine side of the switch.
2. With a pencil, very carefully trace the "exact" profile of the starter switch, the starter switch rod tube angle, & the starter pedal rod angle to witness that the starter switch rod tube angle has to be changed for proper alignment with the "operable" starter switch pedal rod when it moves up & down at an angle in the "ON" & "OFF" position.
3. With a Dremel tool & an abrasive cylinder, carefully grind the new switch's metal circular opening until it is elliptical; hence, such that the starter rod tube angle can be adjusted up & down in the enlarged elliptical opening to match the angle of the starter pedal rod.
4. Be careful to first get the "exact" angle required from your cardboard diagram so as to not make the switch's elliptical opening too large.
5. Worked for me -- little at a time, patience, & try until you get it right to where it cannot jam & stick in the depressed "ON" position.
H. L. Chauvin is offline   Reply With Quote
Old 10-16-2013, 02:04 PM   #7
41plym
Thanks H.L. mine is also sticking in the start position. My thought is why should I have to do this with a brand new "exactly like the original" part. I'm happy to pay a more for quality replacement parts.
41plym
Old 10-16-2013, 02:27 PM   #8
1931 flamingo
1931 flamingo's Avatar
Because they're NOT "exactly like the original"..............................
Paul in CT
Old 10-16-2013, 07:05 PM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
My friend had the same problem with his new switch. I wonder if this is a new problem, as I don't recall anyone having problems in the past.
I was lucky to find a good original switch at my last swap meet.
Old 10-16-2013, 07:18 PM   #10
DougVieyra
DougVieyra's Avatar
Have you contacted the vendor / parts house that you bought the switch from? Usually they not only want to help you solve the problem (refund, better part, etc) but they want to hear from the user - what works and what does NOT work. They can't be motivated to change their suppliers unless they hear negative reviews from the user. Let them know - they want to hear from you. You should not have to resort to the time, effort, hassle, as H. L. Chauvin had to go through.
DougVieyra is offline   Reply With Quote
Old 10-16-2013, 09:18 PM   #11
H. L. Chauvin
Have no idea if good "new" starter switches are available to vendors -- many vendors still sell the "Vintique" brand.
Old 10-17-2013, 10:11 PM   #12
spdway1
spdway1's Avatar
I called A&L in CT today, "they do not reproduce them yet" The only new one available is a Vintique they told me. So I will use the new one I have here.
spdway1 is offline   Reply With Quote
Old 10-17-2013, 10:22 PM   #13
Phil
Phil's Avatar
Had the exact problem yesterday, found a serviceable original. We need to tell the venders and they need to be all over the manufactures. If we don't complain we will keep getting this crap.
Phil is offline   Reply With Quote
Old 10-21-2013, 06:30 PM   #14
41plym
I just bought a nors one off eBay for about the same price as the junk ones sold by the suppliers.
41plym
Old 10-21-2013, 06:35 PM   #15
H. L. Chauvin
Maybe try it as soon as you get it -- could be a new or old "Vintique" if the seller was possibly misinformed.
Old 10-21-2013, 07:05 PM   #16
41plym
Thanks H.L. but I'm sure it's nors it comes in the original box
41plym
