Old 08-24-2013, 11:20 AM   #1
gilitos
gilitos's Avatar
Default Is there hope for this hood?
This is a reproduction hood that I bought from Snyder's back in the mid '80's. You can see it is not shaped quite right. Has anyone had any experience getting one of these to fit? I'm wondering what's involved. Any suggestions?
gilitos is offline   Reply With Quote
Old 08-24-2013, 11:26 AM   #2
Rowdy
Default Re: Is there hope for this hood?
An experienced person with an English Wheel would be able to shape it right. Not sure how much it might stretch and move the beltline though. It would need repainted after the work. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 08-24-2013, 11:45 AM   #3
Logan
Logan's Avatar
What does the front of the hood look like around the radiator shell? It may not be the hoods fault it looks like that. To me it looks like the cowl section of your body needs to be raised up to compensate for frame sag. Even if your doors close really nicely that doesn't mean your frame is strait, it just means someone took enough time to shim the body, and the body only. Not the body with the hood on. There was a Tudor here in the dfw and the guy was real particular on how he wanted the car to look. The car restorer only shimmed the body so the doors would close, not the entire car as a whole. He brought us the car right after he got it back from the "restorer", and yes the frame was sagging after being told from the "restorer" that the frame was straitened. It may have been straiten than when it started, but it was not strait. So since the car was all together, and with the mans permission and with him standing there, we chained the car to the floor and jacked up on the frame rails until we got the hood fit perfect. I'm not saying this is what you need to do, but this is what we did in his case because of how bad the sag was. Yours maybe able to be fixed with shims under the cowl.
Cowtown A's
Logan is offline   Reply With Quote
Old 08-24-2013, 02:58 PM   #4
Ross/Kzoo
Ross/Kzoo's Avatar
This is probably a dumb question/response but why couldn't the removed hood be taken off and placed on a 4", or whatever size, PVC pipe and "coaxed to tighter radius?
Ross/Kzoo is offline   Reply With Quote
Old 08-24-2013, 03:18 PM   #5
gilitos
gilitos's Avatar
I believe that there is some frame sag to take care of, but that the sag is the cause of a different issue: the large gap between the bottom of the hood and the cowl. Looking at this thing from every angle I feel like this big gap at the top is not frame sag but from too large a radius on the hood bend. And Ross, my fear about trying to bend it over a piece of pipe would be ending up with a kink in the hood instead of a smooth radius. I wonder, though.
Old 08-24-2013, 03:33 PM   #6
Ross/Kzoo
Ross/Kzoo's Avatar
I spent a few hours with a metal former to make up a custom dogleg for a modern car. You wouldn't believe how many times he went to the anvil or whatever suited his purpose and with his gloved hands did some amazing forming. I would just dis assemble the hood and take each top panel and slowly work that hood to a tighter radius.
I hope that more experience metal formers will jump in here.
Old 08-24-2013, 03:39 PM   #7
1931 flamingo
1931 flamingo's Avatar
gilitos: If you've ever followed any real street rod builds that's how they usually do it, over an oxy/acty tank. High end shops use "bucks",etc. First place for you to probably start is with frame sag, shims,etc. JMO
Paul in CT
Old 08-24-2013, 03:54 PM   #8
gilitos
gilitos's Avatar
Ross and Paul, your advice rings true. I am about to begin a partial dismantle to tackle the frame sag and some paint issues and I'm going to give it a try. Thanks.
Old 08-24-2013, 03:59 PM   #9
grapp
You can bend that hood fairly easy and if you use a tank, or something with a slightly smaller radius than the cowl (as it will spring back a bit) you'll be fine. It probably won't break the paint either. However as you stated if you have a gap at the lower hood you need to fix your frame sag first before you go muscling the hood around.
grapp is offline   Reply With Quote
Old 08-24-2013, 06:21 PM   #10
Keith True
Keith True's Avatar
I've seen quite a few hoods like that.They got that way from being thrown flat on the barn floor,then walked on over the years.I just roll them over a piece of well casing until they fit.The hardest part is the on/off on/off until they fit.The only guy I know with an english wheel said it is not a job for the wheel,as it is too localized.You have to support it the whole length when you bend it.It really is one of the easiest fixes you will ever do,that produces good results.
Old 08-24-2013, 06:26 PM   #11
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Sometimes a little help can be had by adding supplied spacers under the hood center rod rear bracket goodie. Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 08-24-2013, 10:56 PM   #12
tbirdtbird
Bill, that is exactly what I was thinking.....
It also looks like the hood has been opened and thrown over the top thus exaggerating the mis- fit even more...maybe not but never open the hood past vertical and be sure to use a prop rod or support rod that most everyone has added to their car.....
'31 180A
tbirdtbird is offline   Reply With Quote
Old 08-25-2013, 12:26 AM   #13
Marco Tahtaras
Marco Tahtaras's Avatar
Logan's post struck note that made me think. Even a hood with poor curvature would normally pull down better than that. It made me realize that the radiator shell is holding it back and up as the mentioned frame sag would contribute to.
Unlatch the hood latches and let the front bottom corner of the hood sides overlap the radiator shell if it wants to. Next, pull down on the hood handle firmly and see if the outward gap closes with the lower front hood sides overlapping the shell. If so then a sagging frame IS the primary problem.
Repro hoods are not great but it's important to determine the actual cause of each issue and not blame them all on one item without reason.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 08-25-2013, 01:47 AM   #14
BILL WILLIAMSON
Vermin, my Avatar '29, has what I believe is an early Issac Kramer repro radumator & it has them hooks on the top tank to hold the hood up. It even still has the hook clips on the bottom tank for the headlight wiring crossover. It doesn't leak & looks as if it has NEVER had any repairs. Shortly I'll be firing him up & see how it cools. Supposedly, it was built with an increased capacity in the top tank, which extends about 3/4" in back of the shell. I'm anxious to compare it with an original. Bill W.
Old 08-25-2013, 07:27 AM   #15
Kevin in NJ
Repro hoods are flat at each end and through the louvers. Put a ruler on the louvers and it will lay flat.
Original hoods are curved to match the rad shell and cowl. The differential curve flows though the louvers. Put a ruler on the louvers and it will rock evenly end to end.
You can put a slight bend at each end of the repro, but trying to make the bend go through the louvers will not end well. The louvers are lifted off the main flat level and need to be stretched or they will pull down. Simple outer radius needs to go a longer distance.
Something to keep in mind.
For your problem follow Marco's advice.
