Old 08-21-2013, 03:34 PM   #1
Pete Fl/Wi
Pete Fl/Wi's Avatar
Default AV8 radiator/fan clearance ?
I am going to trial fit my 8ba with stock fan, 39 trans and k member to my A frame tomorrow with the radiator in stock position. Question is, how close can I have fan to radiator or what is recommended clearance?
Thanks Pete
Pete Fl/Wi is offline   Reply With Quote
Old 08-21-2013, 04:19 PM   #2
28ACoupe
28ACoupe's Avatar
Default Re: AV8 radiator/fan clearance ?
This question is probably better suited for a hotrod forum such as http://www.jalopyjournal.com/forum/
This forum is for restoration/light modifications.
Cheers,
1928 Model A Business Coupe
Rebuild picture gallery here
The light at the end of the tunnel has been turned off due to budget cuts.
28ACoupe is offline   Reply With Quote
Old 08-21-2013, 07:42 PM   #3
bobscogin
Need to allow about an inch clearance, but if you have the stock firewall and radiator locations, the 8ba probably isn't going to fit. I used the early single belt and it was a squeeze.
Bob
bobscogin is offline   Reply With Quote
Old 08-22-2013, 08:35 AM   #4
Jack 34pu
Jack 34pu's Avatar
Don't be discouraged. One of the earliest mods to the Model A was the swap of a flathead V8. I lurk on this and the V8 forum and find there are many who have interests in both restoration and slight modifications. The V8 forum is a little warmer to your interests but many good people on both. I too, have an interest in your question as I have started probably my last project - a 28pu with a '50 Merc bored .080". I'm not ready to set the motor but will need any info you find on clearances. Thanks for asking and hope those on this forum who secretly have 'special' projects will share their knowledge.
Jack 34pu is offline   Reply With Quote
Old 08-22-2013, 09:15 AM   #5
machine girl
would like to see ryan set up a modified site for us rebels!!
machine girl is offline   Reply With Quote
Old 08-22-2013, 09:30 AM   #6
Jim Brierley
As bobscogin says, it may not fit as-is because the 8BA is longer than the 59A. It may be easier to modify your engine to 59A specs?
Old 08-22-2013, 09:35 AM   #7
Rowdy
Unless you want to move the radiator or cut the firewall you should use the 59A waterpumps. There are some other pulley and generator changes that have to be made to make it work. I have a 37 21 stud and am going to have to find. A pair of 59A waterpumps also along with changing to a pancake style dist. Likely I will. Start setting up the chassis this winter. I basicly have everything needed, so it is a project I can get the farthest on over the winter. After the fab work is done this project will go back to storage in the barn for a couple of years while I try to finish catching up med bills. Then will rebuild the engine and start body work. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 08-22-2013, 10:59 AM   #8
Bruce Lancaster
100% agree, but it is only really practical if engine is still being rebuit...early cam and pumps, '42 distributor, single belt system will save you several inches over 8BA and solve its ignition problem as well. I have a post somewhere on HAMB with dimensional study of this.
Old 08-22-2013, 12:07 PM   #9
George Miller
George Miller's Avatar
It is tight fit, but both V8 flat heads will fit. Your real problem is the steering gear.
I also like stock cars, but I want them stock. But I also like hot rods because you can build them the way you want.
The 49=53 flat head in the roadster, I had to use a different fan. Best to use the water pumps from the older V8's
George Miller is offline   Reply With Quote
Old 08-22-2013, 12:45 PM   #10
Purdy Swoft
Purdy Swoft's Avatar
I used the generator with the fan mounted on the pulley. This worked good , first with the 60 horse flathead and later with an 85 horse 1940 flathead. The 49-53 truck and Mercury water pumps have the front motor mount ears to the side like the 59A and earlier flathead water pumps.
Old 08-22-2013, 12:54 PM   #11
29restorod
29restorod's Avatar
If you change to early V8 water pumps, you will also need to change the cam, timing gears, and front cover. I always build the other way, take a 59 AB and build it like a 8 BA.
If you think SBC's are "Old School" you are not old enough.
29restorod is offline   Reply With Quote
Old 08-22-2013, 06:00 PM   #12
pooch
pooch's Avatar
I asked a year ago for a dedicated modified/ hotrod A forum.
He point blank refused.
pooch is offline   Reply With Quote
Old 08-22-2013, 06:28 PM   #13
PeteVS
PeteVS's Avatar
There's an AV8 social group on the Early V8 forum, but it hasn't been too active.
Old 08-23-2013, 07:04 AM   #14
grapp
Well there is so much info on the H.A.M.B that it really isn't necessary to have it here... go check it out, tons of guys have AV8's over there...
grapp is offline   Reply With Quote
Old 08-29-2013, 08:39 AM   #15
flatheadz-forever
still a good thread
flatheadz-forever is offline   Reply With Quote
