Old 07-19-2013, 07:26 PM   #1
Ed Northrop
Ed Northrop's Avatar
Default Modern shocks
Does any one have any information on modern shock kits like Ken Davis makes. Does this improve the ride and handling of the model a.
Ed Northrop is offline   Reply With Quote
Old 07-19-2013, 07:55 PM   #2
Smitty
Smitty's Avatar
Default Re: Modern shocks
After rebuilding my shocks 3-times in the past 5 years I had enough. I built my own shock mounts and installed the rears so far. The difference in significant, corners, handles and rides much better that it ever has.
When you look at kits be sure that shock has plenty of travel room.
Steve
Smitty is online now   Reply With Quote
Old 07-19-2013, 08:01 PM   #3
Skeezixx
Skeezixx's Avatar
I just installed a CMR kit. No drilling required and comes with Monroe Gas-Matic shocks. It made a huge difference in the way the car handles.
I like em.
Skeezixx is offline   Reply With Quote
Old 07-19-2013, 08:09 PM   #4
tbirdtbird
ken davis has complete kits for this: brackets already fabbed and shocks ready to go
http://www.kendavismodela.com/Shocks.html
if you are not familiar with Ken his stuff is first class
he supplies full AC kits also
'31 180A
tbirdtbird is offline   Reply With Quote
Old 07-19-2013, 08:17 PM   #5
Mark Earl
After some exhaustive research I have also decided to go with a Ken Davis kit for my 30 roadster. I contacted him yesterday via email to ask for a shipping quote to Canada, and received 2 different quotes this afternoon. Because the shipping cost was a little high for the full kit, he quoted me the shipping and cost for just the brackets, and sent me the part numbers for the shocks to buy locally. Communication has been excellent so far. Either way I'm buying something from him.
Mark Earl is offline   Reply With Quote
Old 07-19-2013, 09:38 PM   #6
Skibb
Skibb's Avatar
I have 1,500 miles on a set of modern shocks that are excellent. My car has new springs front and rear and each leaf has a beveled edge. So what? Right, the car needed shocks. These are Monroe gas shocks from Dick Pirkl, Tubular Conversions, 608 573 7433. Priced about mid 300 plus shipping should be twice that based on the ride.
Skibb is offline   Reply With Quote
Old 07-19-2013, 09:43 PM   #7
KGBnut
KGBnut's Avatar
I installed a Ken Davis kit in 2011. At that time, I wrote a rather detailed post about the my experience with installation. I will re-post it below.
It has now been a year and a half since the install and I am just as happy, if not happier with them. I would definitely buy Ken's kit again.
From November 2011
https://www.fordbarn.com/forum/showth...0895&showall=1
I finally got around to installing the shocks that I got from Ken Davis. I'm very pleased with how the installation went. Ken's instructions are practically non-existent, however, it is fairly obvious how they go in. If you have the old Houdaille shocks in the car, you will need to remove all the old linkages.
The fronts went together very easily. You need to remove the original Houdaille cylinder. The upper bracket mounts in the original Houdaille mounting holes. Don't be confused by the one extra hole in the bracket. It is there to clear a frame rivet. The lower front bracket does require drilling a 3/8" hole through the front axle. I know...it is not easy to drill a hole through our precious Henry Steel, but (a)these axles are plenty strong enough to manage it, (b)if I ever change back that hole can easily be welded back up, and (c)I'm not that much of a purist. The hole is drilled about 4" from the spring perch. Spend a little time to ensure that you put it where you will get the best clearance as the axle travels.
The rears do require the removal of the brake drums. The lower brackets bolt right through the brake backing plate. Here I encountered my only disappointment with the design. The original nuts that secure the bolts through the backing plates have a built-in spacer to fit into a recess. The ones that come with the kit don't. And, the new bolts are a different thread, so you can't reuse the old nuts. I made some small spacers to compensate, but if I had to do it over again, I would take the time to get longer bolts the same thread as the originals, drill a cotter pin hole through them, and reused the original nuts.
The location to attach the upper brackets for the rears was a little tricky to find. Look directly above the springs and you will find two bolts through the frame. It is secured by those bolts above the frame. Once I found the holes they were easy to mount.
Really taking my time on a pretty cold day, the whole job took the better part of the morning. I still had time for a test drive before lunch.
To be fair, my 1930 Coupe had no shocks at all, and I have no experience driving one with the original Houdaille shock, so I can't compare them. However, compared to driving with no shocks, she is an entirely different car. The improvement in handling and control is remarkable. She is stable around sharp corners, and no longer skitters across the road when hitting rough pavement. The new shocks make her a pleasure to drive, and I believe the increased control makes her safer.
Obviously, the shocks do not look stock, but they don't show much at all. When I get a chance I'm going to crawl under there with a can of flat black and I'm sure they will disappear.
Would I but this kit again? Absolutely! This kit was the most affordable of any of the options I looked at, right around $200.00 for the complete kit ready to install. The brackets are sturdy and well made. Ken was easy to work with and his turn around time was pretty good. And most of all, my wife is now happier to ride with me.
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 07-19-2013, 10:10 PM   #8
Pat Martone
Pat Martone's Avatar
I installed Ken Davis shocks recent; they are great and my car rides better and seems to be more stable too.
Pat Martone is offline   Reply With Quote
Old 07-20-2013, 12:09 AM   #9
Jordan
Jordan's Avatar
I have Ken's shocks on my car. Rides & handles great. A way better & cheaper option than paying $1,000 for rebuilt shocks.
Cowtown A's
Jordan is offline   Reply With Quote
Old 07-20-2013, 06:47 AM   #10
sidhartha
sidhartha's Avatar
I put a set on my 31 Tudor. It had no shocks at all when I got it. I search and found a number of options but most required drill the front axle or rear frame. I settled on a set from Ryan Kaye. They clamp to the front axle and are very solid. The rear uses existing holes in the crossmember where the rear bumper mounts. I did have to drill out two exsisting holes in the backing plate. They were $310.00 for 4 mounts and a set of Gabriel shocks. The rides much better and it eliminated my issues with body roll.
sidhartha is offline   Reply With Quote
Old 07-20-2013, 10:45 AM   #11
CarlG
CarlG's Avatar
Ken Davis shocks here, love them.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 07-20-2013, 11:32 AM   #12
Terry, NJ
Terry, NJ's Avatar
I hated to do it! It involved drilling two (L & R) 5/8" holes in my chassis! For me, That was painful! My New coupe already had a "Kit" on it so I just duplicated the pieces from angle iron , drilled the appropriate holes, bought some "Graded" fine threaded hardware and installed the kit. Next, I took the old shocks off and tried to get the numbers off them. No way, Too rusty. So we tried to match as close as we could come. I bought Monroe, Gas-matics # 59017 and put them on. Are they good? I suppose so. The car rides hard (next to a modern car) is that a function of the springs or the shocks? But It stays on the road, doesn't lean in corners. What more can I ask?
For pics of this, go to my profile and come down to "My A".
Terry
Old 07-20-2013, 02:33 PM   #13
Skibb
Skibb's Avatar
Terry, did the ride change at all with the new shocks? Monroe gas shocks are on my car and improved the ride. It's still a Model A but it ride's good.
Old 07-20-2013, 04:25 PM   #14
Ed Northrop
Thanks for all of your comments, this is great information
Old 07-20-2013, 11:53 PM   #15
CarlG
CarlG's Avatar
From November 2011
I finally got around to installing the shocks that I got from Ken Davis. I'm very pleased with how the installation went...
The rears do require the removal of the brake drums. The lower brackets bolt right through the brake backing plate. Here I encountered my only disappointment with the design. The original nuts that secure the bolts through the backing plates have a built-in spacer to fit into a recess. The ones that come with the kit don't. And, the new bolts are a different thread, so you can't reuse the old nuts. I made some small spacers to compensate, but if I had to do it over again, I would take the time to get longer bolts the same thread as the originals, drill a cotter pin hole through them, and reused the original nuts...
The same bolts that hold the radius rods and the forward half of the backing plate work there like a charm. I just bought 4 of them from Snyders and used them instead of the bolts that came with the kit.
Alaskan A's
Old 07-21-2013, 06:24 AM   #16
Terry, NJ
Terry, NJ's Avatar
Actually, I put them on soon after I got the car. I really was too focused on other things to notice the what the ride was like. As I said, the ride is hard. But is that because of the of the springs, not the shocks.
Terry
Old 07-21-2013, 06:25 AM   #17
KGBnut
KGBnut's Avatar
CarlG,
That's a great tip! Could you give me a link to the correct part on Snyder's website? I will swap them out the next time I have the brakes apart.
Ken
Old 07-21-2013, 08:08 AM   #18
Skibb
Skibb's Avatar
Terry
Terry, I'm a novice. Wish I could tell you true with the nuts 'n bolts of it. But My car had replacement springs but worn out shocks. Oh, we had a nice enough ride until we met a corner. Ole Dick Pirkl fixed us up. We put a second set of his on the restoration car.
Old 07-21-2013, 08:31 AM   #19
Terry, NJ
Terry, NJ's Avatar
This best and quickest way to discribe what a shock does is to say it's a "brake" for the spring. The shock absorber slows the action of the spring. Don't quote me on this, but If a shock is too stiff , it slows the spring too much and it will ride hard. If it's too light, it will not slow the action of the springs enough and the ride will be bouncy. The shock I used is actually a little to heavy/stiff and the ride is a little hard, The upside of this is that the car corners good. I'm satisfied with it. I sailed around a fairly sharp curve at 40-45mph with it two days ago and the car didn't lean a bit.
Terry
Old 07-21-2013, 06:57 PM   #20
Skibb
Skibb's Avatar
[QUOTE=Terry, NJ;692202. The upside of this is that the car corners good. I'm satisfied with it. I sailed around a fairly sharp curve at 40-45mph with it two days ago and the car didn't lean a bit.
Terry, your A has to be named or renamed "Jr Johnson".
