Old 07-07-2013, 01:15 PM   #1
fredski
fredski's Avatar
Default grease nipples need help on this
i took out some grease fittings that were pressed in only and ordered modern type and they are all threaded fittings in a kit
how can i use these,they were ordered from model a supplier??
fredski
fredski is offline   Reply With Quote
Old 07-07-2013, 01:58 PM   #2
Elcastor
Elcastor's Avatar
Default Re: grease nipples need help on this
The suppliers have the pressed in type also. Whenever I have ordered a kit with all grease fittings needed for a Model A, I have always gotten the correct types. Some are press fit, and some are threaded.
Ben Purkey
Mexico and the Pacific NW
http://www.martin-parry.com/
Elcastor is offline   Reply With Quote
Old 07-07-2013, 02:34 PM   #3
redmodelt
redmodelt's Avatar
The press in ones have ridges that look like they are threaded but if you look close the ridges are rings. Some of them are a very tight fit so make sure what you are putting them into is well supported.
Old 07-07-2013, 03:30 PM   #4
Roadster62
Roadster62's Avatar
You also need the special tool to drive them in without damaging the ball. Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical.
Roadster62 is offline   Reply With Quote
Old 07-07-2013, 05:02 PM   #5
Mike V. Florida
Mike V. Florida's Avatar
fredski
You have to thread the holes to use the modern fittings.
Old 07-07-2013, 07:46 PM   #6
glenn in camino
glenn in camino's Avatar
My repo grease fittings do not have a spring or check ball. Does someone make authentic Model A grease fittings?
Old 07-07-2013, 10:07 PM   #7
redmodelt
redmodelt's Avatar
Sounds like he ordered the kit. You do not have to thread the holes, look close as I stated. While I can't tell where each grease fitting went I think some did not have check balls in them originally.
Old 07-07-2013, 11:02 PM   #8
Mike V. Florida
He said he ordered the modern type, 1/8 pipe thread.
Old 07-08-2013, 07:13 AM   #9
fredski
fredski's Avatar
thank you for all your help.
I now see I have some in kit with ridges and some threaded.
did not look close enough when looking in bag of fittings.
fredski
