Old 05-29-2013, 12:24 PM   #1
Afordman31
Afordman31's Avatar
Default Speedometer Drive Gear
I have the round 30-31 speedometer which has a drive gear of 19 tooth, this is for the 3.78-1 axle ratio with 19 inch wheels. What I want to do is change the drive gear to a different tooth to make up the speed difference of putting on 35 Ford 16 inch wheels. I called Bert's they said to use a 20 tooth gear. Any thoughts on this appreciated.
Afordman31 is offline   Reply With Quote
Old 05-29-2013, 01:30 PM   #2
CarlG
CarlG's Avatar
Default Re: Speedometer Drive Gear
If Phil or Steve at Bert's said it, you can be certain that what they said is 100% correct.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 05-29-2013, 02:33 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Bert's is right. If you install a smaller diameter tire then you won't be going as fast as indicated on the speedometer, so you need to slow it down a bit. Adding a tooth to the DRIVEN gear will slow it by about 5%.
I always check mileage for accuracy first, then the speed (if not correct) is adjusted inside the speedometer.
