Old 05-26-2013, 03:25 PM   #1
modelamodela
Default 47 Flathead carburater woes
Have a 47 flathead running on a Holley 2100 with a Purolater electric fuel pump and a flow meter set at 2.5. Starts up easily, runs and drives for 10 minutes, then looses power and stops. With effort, it will restart but stops again. After waiting an hour or so, will start up fine, run another 10 minutes or so, then stops again. Feels like fuel starvation, but hey, what do I know !!! What is the problem??
modelamodela is offline   Reply With Quote
Old 05-26-2013, 04:43 PM   #2
ken ct
Default Re: 47 Flathead carburater woes
Either a faulty pump,clogged fuel filter some where OR coil problems,Take your pick ken ct.
ken ct is offline   Reply With Quote
Old 05-26-2013, 04:55 PM   #3
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
The next time it does that when the engine is hot, pull a couple of plug wires and hold the wire about 1/4in. from ground, like the head, and have someone crank the engine and see if any spark. It sounds like bad coil. You could send that 46-7-8 coil to Ship Hanney in Fl. and have rewound, you'll never have a hot starting problem again. Walt
Old 05-26-2013, 06:44 PM   #4
Willit Stop
Willit Stop's Avatar
If it was me,I would run it until it stops,then pour a LITTLE splash of gas in the carb. If it starts right up....it's a fuel problem. Good luck.
Willit Stop is offline   Reply With Quote
Old 05-26-2013, 06:50 PM   #5
randymo9
just had same issue with my 46 coupe flathead. coil replacement with modern style coil and has run well since randy
randymo9 is offline   Reply With Quote
Old 05-26-2013, 07:02 PM   #6
flatjack9
flatjack9's Avatar
Condensor?
Old 05-27-2013, 12:16 AM   #7
Dick's Hot Rod Place
Dick's Hot Rod Place's Avatar
Unscrew your gas cap and see if that don't cure the issue.
www.dickshotrodcarbs.com
Dick's Hot Rod Place is offline   Reply With Quote
Old 05-28-2013, 05:38 AM   #8
JWL
Some good suggestions already here---
First, when it begins to stop, add some fuel and observe the response. Sometimes pulling the choke can give a clue. Next, check for spark. If spark is weak or intermitent the first change should be the condensor.
JWL is offline   Reply With Quote
Old 05-29-2013, 02:49 PM   #9
Bruce Lancaster
The typical coil failure will behave like what you describe...when I first encountered it as a teenager I failed to diagnose it because it would always produce a spark even while still hot. I eventually learned that what I saw, a thin yellowish spark, was the indicator, and that the satisfactory spark produced when the coil was still cold was fat and blue with a satisfying SNAP to it.
Old 05-29-2013, 04:24 PM   #10
Kerk
I was with a group coming back from a Georgia meet and a 46 in the group KEPT HAVING "vapor lock". After 3 or 4 stops I said we should change the coil! I had the modern type which we Micky Moused the wiring and laid the coil on the Intake and drove the rest of the way home with no more problems. Just my experience for what it is worth. I always carry a spare coil and condensers.
Kerk is offline   Reply With Quote
