Old 03-19-2013, 04:30 PM   #1
Dune Country
Default gluing down top bubbles
'31 CCPU prior owner welded a steel top on it.
drilled holes 2" apart and installed fabric and hide-um with pop rivets in the sunshine here yesterday.
put her in the shop, this morning there are a couple of small bubbles, Tried to drill out a couple of the rivets to pull the fabric and they spun almost tearing the fabric.
My thought is to use a syringe with a needle and squirt some glue into the little bubbles. Anybody done this? and know of a thin type of glue that will squirt?
tnx
Greg
Dune Country is offline   Reply With Quote
Old 03-19-2013, 04:54 PM   #2
CarlG
CarlG's Avatar
Default Re: gluing down top bubbles
My '31 CCPU came from the factory with a steel top. Just saying.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-19-2013, 06:27 PM   #3
Dune Country
no yelling here, want to use something slower drying than super glue, any ideas on a watery type of slow glue?
Old 03-19-2013, 06:37 PM   #4
luckyal
I would go for a faster dry and use a warm clothes iron on it after the glue is injected or a hair dryer.
Al
luckyal is offline   Reply With Quote
Old 03-19-2013, 06:39 PM   #5
P.S.
Epoxy!
P.S. is offline   Reply With Quote
Old 03-19-2013, 07:22 PM   #6
Mitch//pa
i have used quick dry epoxy in a syringe for my running board mats when they had an air bubble. the syringes actually come with the epoxy that we use at the shop. inject and place a flat heavy object on it
Old 03-19-2013, 10:00 PM   #7
FL&WVMIKE
FL&WVMIKE's Avatar
Dune Country .........
You can safely slice your bubble with a razor blade and when you glue it down, it will be totally sealed.
Like CarlG says, it might be factory.
MIKE
FL&WVMIKE is offline   Reply With Quote
Old 03-19-2013, 10:07 PM   #8
luckyal
The problem with epoxy and a flat heavy object is that the epoxy may leak out and adhere to the flat heavy object !
Al
Old 03-20-2013, 06:32 AM   #9
Mitch//pa
Originally Posted by luckyal View Post
The problem with epoxy and a flat heavy object is that the epoxy MAY leak out and adhere to the flat heavy object !
Al
have done it many times with a syringe the size of a needle point, quick cure 2 min liquid epoxy and very little product injected. until you or your mechanic try's it lets not be hypothetical. i am just sharing my experiences that i have had success with to help others
Old 03-20-2013, 07:12 AM   #10
luckyal
and I am also shareing my experience and injecting some common sense into the solution ! My mechanic has nothing to do with it !!
I prefer no risk and your method has risk involved.
Al
Old 03-20-2013, 11:08 AM   #11
P.S.
Lay a sheet of plastic wrap over the repair before placing the heavy object on top. The plastic wrap peels away from the cured epoxy with ease (assuming there's nothing already on the plastic wrap).
Have been building model airplanes for almost 35 years, have LOTS of experience with epoxy.
Old 03-20-2013, 11:45 AM   #12
luckyal
PS
The plastic makes lots of sense ! Thanks for the better idea !!
Al
Old 03-20-2013, 12:42 PM   #13
Tom Wesenberg
Tom Wesenberg's Avatar
I use wax paper when I glue boards together and don't want the glue to stick to the clamps.
Old 03-20-2013, 12:43 PM   #14
1931 flamingo
1931 flamingo's Avatar
Before cutting or glueing I would try a heat gun. JMO
Paul in CT
Old 03-20-2013, 01:54 PM   #15
TonyM
TonyM's Avatar
Yep, that's how I do it.
Same here over 30 years of model building did come in handy in the old car hobby for me too.
TonyM is offline   Reply With Quote
Old 03-20-2013, 08:39 PM   #16
rons49
rons49's Avatar
How about concrete adhesive? It is very milky( latex) cleans with water and impervious to heat & easily injected. I repair concrete overlay that way. Another might be clear Liquid Nails. It takes a few hours to cure.
rons49 is offline   Reply With Quote
Old 03-20-2013, 09:12 PM   #17
ronn
Rubber cement and a razor blade....
Old 03-22-2013, 01:10 PM   #18
Dune Country
Thanks for all of the reply's.
I like the plastic wrap or wax paper, use it when doing fiberglass also.
Razor blade would work also.
I have taken some scrap material and glued it to steel with elmers, trim adhesive and super glue, didn't have a chance to check it this morning.
My shop came with a 1 ton Jet electric hoist, had the engine up on a bench to install the trans, lifted 'er up, removed the saw horses and it wouldn't go down,
got out the ladder and turned out the contactor points are burned, called to order points and have to buy the whole contactor unit ($350.00)!!!
I'll be taking a chain fall from work to get the engine down and cruising the net today for points.
Old 03-22-2013, 01:46 PM   #19
super flat
super flat's Avatar
Are you sure you cant clean them and true them up? Gary
super flat is offline   Reply With Quote
Old 03-22-2013, 02:41 PM   #20
Dune Country
nope, 2 are fried down to the base plate, not having much luck finding them either.
might just silver solder some on if I can find them.
