Old 02-23-2013, 09:28 PM   #1
Willit Stop
Willit Stop's Avatar
Default Top Dead Center By Water Bubble
Take an old spark plug from your box of spare parts that you "might need someday".Today is the day.Cut the crimp off just above the hex with a hacksaw.Cut the ground off and drive out the porcelain being careful not to damage the threads.Scrape the hole out clean.Now you'll need about 5'of clear vinyl hose (I used 7/16 o.d.x 5/16 i.d.)and a grommet to use as a seal.Slide the grommet onto one end of the hose and insert this into the large end of the sacrificial plug.BTW you can click on the photo to enlarge.
Remove all of the spark plugs and place #1 wire close to a good ground ( you may have to pull the boot back a little).Turn the ignition switch on.Shift the transmission into high gear and slowly roll it forward by rotating the front wheel just until the spark occurs.Now roll it back a little.Turn the switch off.Screw the now altered spark plug and hose into #1 cylinder. You don't have to use a dying stain here.Snug will do.Next,loop and tape the hose to the radiator support rod.Pour just a little water into the open end of the hose so you have about a 4" bubble of water in the bottom of the loop.Grab the front wheel with your now greasy hands and SLOWLY roll the car forward a little at a time.Watch the bubble,it will return back to the bottom of the loop in a few seconds.The upstroke of the piston will force the bubble to the open end of the hose(BTDC) and the down stroke will draw it towards the cylinder(ATDC).Pretty simple huh? Roll the wheel forward just until the bubble decides to change direction.TDC. Done.With a little luck,George/Maine will respond with his directions on how to do the final timing.I tried it and it works great! Thank you sooo much George.
Willit Stop is offline   Reply With Quote
Old 02-23-2013, 09:52 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Top Dead Center By Water Bubble
Need to really emphasize that LOOP part of the equation, so as to keep water from reaching cylinder. Not a bad idea though, in theory. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 02-23-2013, 09:59 PM   #3
woodypecker
woodypecker's Avatar
I have done something similar overdid the down stroke and sucked water into the cyclinder and I now use oil instead of water.
woodypecker is offline   Reply With Quote
Old 02-23-2013, 10:28 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
Not to steal any "thunder" from your thread, but the link below shows another somewhat similar idea currently floating around on the H.A.M.B. DD
http://www.jalopyjournal.com/forum/s...d.php?t=778434
T5 W/TORQUE TUBE
Old 02-23-2013, 10:45 PM   #5
Willit Stop
So do you use this before or after you uh...........Oh, never mind.
Old 02-23-2013, 10:48 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
Depends on one's priorities, I'm guessing. Good one! DD
T5 W/TORQUE TUBE
Old 02-24-2013, 03:46 AM   #7
Mart
Mart's Avatar
Like the water bubble idea, Willit, you have some good ideas.
Mart.
Old 02-24-2013, 09:31 AM   #8
George/Maine
George/Maine's Avatar
  • 0
  • 0
That looks like a good way to find TDC.
George/Maine is offline   Reply With Quote
Old 02-24-2013, 09:47 AM   #9
Ronnie
Ronnie's Avatar
Bin here since 2002 but still a good refresher. http://www.btc-bci.com/~billben/tdc.htm
R
Ronnie is offline   Reply With Quote
Old 02-24-2013, 10:46 AM   #10
Mart
Mart's Avatar
Oh yeah, brilliant. Can anyone tell me how you can judge that No.s 2 and 3 pistons are at the same height in the bore? I can't think how to do it. I think a lot of methods people quote make the assumption the spark plug is over the cylinder, when as we all know, on a flatty the plug hole is over the exhaust valve.
Mart.
Old 02-24-2013, 11:00 AM   #11
Hoop
Hoop's Avatar
If you have a '36 engine with a "diver's helmet" distributor, it's easy to accurately locate TDC ... but you have to think about it a bit.
Many guys get thrown off by TDC discussions involving engines and ignition systems that aren't as slick as the earlier flatheads.
Still like seeing guys experiment.
"Remember that when it comes to intelligence, half of all of us are below average."
Hoop is offline   Reply With Quote
Old 02-24-2013, 11:43 AM   #12
V8COOPMAN
V8COOPMAN's Avatar
Mart.
Mart...Think FIRING ORDER.....15486372. After #3 fires, #7 will be the next to come to TDC. While #7 is at TDC, #3 has proceeded to exactly half-way down it's respective bore. Since #2 will be the NEXT to fire (while #7 is still at TDC), #2 will be EXACTLY half-way UP in it's respective bore. Half-way UP (#2) and half-way down (#3) equeal same height in respective bores. DD
T5 W/TORQUE TUBE
Old 02-24-2013, 11:58 AM   #13
Mart
Mart's Avatar
I'm not saying they are not in that position, just making the point that knowing this does not help locate TDC in a flatty because you can't measure the positions of the pistons in 2 and 3 bores.
Mart.
Old 02-24-2013, 12:18 PM   #14
V8COOPMAN
V8COOPMAN's Avatar
Mart.
Mart...I must admit that I NOW understand YOUR point of the irrelevance of the positions of pistons #3 and #2 in this case. DD
T5 W/TORQUE TUBE
Old 02-24-2013, 12:24 PM   #15
George/Maine
Mart.
This was writen in 1943 by Motors Factory Shop Manual
I have never done this test, but I would think it works.
First go out and buy two loly pops," Reds ones".
When they are about even thats TDC.
Now the angle of the dangle is not the same as TDC
The piston are even about 2" down plus 2" head.
If this method works let it be known.
George
Old 02-25-2013, 01:54 AM   #16
40 Deluxe
Very possibly this was part of the engine overhaul procedure, in which case you simply set the timing BEFORE installing the head!
Old 02-25-2013, 09:45 AM   #17
Hoop
Hoop's Avatar
I posted:
"If you have a '36 engine with a "diver's helmet" distributor, it's easy to accurately locate TDC ... but you have to think about it a bit."
That was a challenge.
(Bubbles, whistles, condoms, even cable ties, are not the way to find TDC on a '36 flathead.)
Old 02-25-2013, 10:31 AM   #18
Ol' Ron
Ol' Ron's Avatar
I think Bruce Lancaster's method of using a large tie rap to find TDC with the heads on is very simple, quick and accurate.
Old 02-25-2013, 10:38 AM   #19
Mart
Mart's Avatar
Originally Posted by Hoop View Post
I posted:
i heard ya, and I love a challenge. I'm wracking my brains but nothin's comin'.
Mart.
Old 02-25-2013, 11:01 AM   #20
George/Maine
I tryed the 2 and 3 cylinder method and it doesn,t work and I wouldn,t use it.
I did the test on 8ba
The way the dist is made you can.t be off to much.
The fixture way is best and its still around.
They must have had arm chair mechinics back then.
