Old 02-10-2013, 01:14 PM   #1
mll1446
Default Oil pan gasket
I am about to install a new self sealing oil pan gasket from Snyders anyone have any tips or problems with this gasket? I have never used, can you yes sealant to hold in place?
mll1446 is offline   Reply With Quote
Old 02-10-2013, 01:46 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Oil pan gasket
Yes.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 02-10-2013, 02:16 PM   #3
mll1446
Can the rear main oil seal be changed while engine in the car?
Old 02-10-2013, 04:00 PM   #4
Ted in MN
The rubbercork gaskets can leak if torqued too tight. Paper gaskets can be torqued to 20 ft-lbs but rubbercork gasket will sqeeze out, try 5 ft-lbs.
Ted in MN is offline   Reply With Quote
