Old 12-31-2012, 11:45 AM   #121
28-31
28-31's Avatar
Default Re: 30 ROADSTER -A hot rod in 1956 - Time for a refersh in 2012
Final Assembly -- glad to see it has begun!
Can't wait to see the rest of the sheetmetal when it's back from the blaster.
28-31 is offline   Reply With Quote
Old 01-19-2013, 09:45 AM   #122
Flop
Jeffs roadster is getting picked up on monday from the blaster !! :
Please call or email while website is down!
412 867 1659
[email protected]
https://www.facebook.com/flop.custom
Flop is offline   Reply With Quote
Old 01-22-2013, 07:39 AM   #123
Flop
thats a whole lotta ford!
the roadster is back in a pile!!
clean clean clean metal
and we couldn't erase history!!
412 867 1659
[email protected]
Old 01-22-2013, 10:43 AM   #124
28-31
28-31's Avatar
I never thought I would ever see it that clean -- looks good.
Here's hoping there are no new surprises, now that there's nothing left to hide old damage/repairs!
Old 01-23-2013, 12:53 PM   #125
PeteVS
PeteVS's Avatar
So, does the blasted metal get sanded smooth before paint, or does a high build primer take care of the texture? I'm amazed at what you've been able to do!
Old 01-23-2013, 07:03 PM   #126
1931 flamingo
1931 flamingo's Avatar
Looks like the cab in post#123 has seen better days. Are you going to resurrect that one also?? Pictures of it would be interesting even though it's not an A.
Paul in CT
Old 01-23-2013, 08:09 PM   #127
PeteVS
PeteVS's Avatar
Paul in CT
I had assumed that it was the cab that was in the truck in post #119 and that for some reason, it came back unblasted but now, I see otherwise. Must have done a swap?
Old 01-23-2013, 08:16 PM   #128
Flop
Thanks Pete. I will take some 80 grit by hand to knock the edge off then it will get epoxy primer .
1931 flamingo this is a 32 ford
the other cab is still at the blasters... he is swamped with work should be picking it up soon!
412 867 1659
[email protected]
Old 01-23-2013, 08:22 PM   #129
buddridge
Hey, if you decide to off the deluxe top and irons call me at 631-335-8260 I'm interested. Thanks Bud
buddridge is offline   Reply With Quote
Old 02-01-2013, 06:47 PM   #130
Flop
well after a few snags we are back in business on the roadster!!
before I get to primer i like the customer to really see whats going on
and the doors
panel under decklid
and the quarter!!
dash rail
i always try to get all the heavy hitting out of the way before primer . so the lip needed to be put back into place!
package tray and inner bracing for the panel under the decklid!
and some more quarter action!
cowl and decklid will be finished up tomorrow!!
412 867 1659
[email protected]
Old 02-02-2013, 03:21 AM   #131
dumb person
dumb person's Avatar
Look at it now! So tidy. (But the firewall pictures way back in post #7 are a little confusing, noticed the hole appears to change position)
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
Old 02-02-2013, 09:21 AM   #132
Weaponsusmc
Weaponsusmc's Avatar
Amazing work.
Weaponsusmc is offline   Reply With Quote
Old 02-02-2013, 01:36 PM   #133
Vin-tin
Vin-tin's Avatar
Hey Flop,
Outstanding workmanship...as always.
Obviously your blaster guy knows what he's doing. The panels came out great. Dou you know what blasting material he uses and at what pressure.
Keep the pictures and tech coming flop. You're the best teacher I (we) have on this old tin.
Vin-tin is offline   Reply With Quote
Old 02-02-2013, 03:08 PM   #134
28-31
28-31's Avatar
Flop was working on two different firewalls -- the first one (stacked up with the other firewalls) is Flop's. The second one is mine -- for the Roadster. Both needed the heater hole area patched.
Old 02-03-2013, 08:10 PM   #135
Flop
as Jeff said ... 2 different firewalls !
thanks weapon !
vin tin . thats why is use him he understands whats going on ! he uses sand. no idea what psi he blasts at .he has a room as large as my whole shop for just blasting .
a few more views of Jeffs roadster before it gets covered in Primer this week!!
and the cowl !
412 867 1659
[email protected]
Old 02-04-2013, 01:05 PM   #136
28-31
28-31's Avatar
All looks great!
What does the blaster do to protect areas like the inside of the gas tank? What do you do, to get all remaining media out of any areas that might still be holding sand (not limited to the gas tank, although that is arguably the most important)?
Old 02-04-2013, 06:09 PM   #137
Flop
Hey Jeff .The tank was taped off . Everything else gets blown off with air then hit with prep sol !
412 867 1659
[email protected]
Old 02-07-2013, 02:26 AM   #138
Spooky Two
Spooky Two's Avatar
Flop, your work is just stunning!!
From what you began with, and havin' taken it through such tedious process's. And now back from the blaster and with all your 80 grit hand rubbing and cleaning. I mean to say, knowing this stuff is meant back as a car, but what good shop and wall art any of these peices would be. Well, I suposes for a short time now they have been just that, great over-in-the-corner art or placed-on-a-counter-top art.We're all talking about it art.
Fact is this is DAMN GOOD WORK. And thanks so much for sharing, S2
Spooky Two is offline   Reply With Quote
Old 02-07-2013, 08:37 PM   #139
Tinbasher
Tinbasher's Avatar
Keep up the Great work!! Nice to see.
The Old Tinbasher
Tinbasher is offline   Reply With Quote
Old 02-09-2013, 07:32 PM   #140
Flop
spooky I cant thank you enough for the kind words!!!
thanks tinbasher!!!
some epoxy primer on today !!!
its nice to see it an actual color ..well its still grey but atleast it has some shine!!!
412 867 1659
[email protected]
