Old 12-31-2012, 04:36 PM   #21
Richard Wilson
Richard Wilson's Avatar
Default Re: My new Model A pickup
Hope you are planning to drive this truck to the Fiddleheads show in April. Should be good to pull trailer for your hillclimb car.
Richard Wilson is offline   Reply With Quote
Old 12-31-2012, 04:57 PM   #22
George Miller
George Miller's Avatar
Richard
Don't think it will be done by then. The hill climb is at Spindale NC this year.
But it is a good idea, may be next time.
George Miller is offline   Reply With Quote
Old 01-01-2013, 09:35 AM   #23
Chris in WNC
Chris in WNC's Avatar
I confess to be something of a purist but I LIKE the way this one is shaping up.
would not mind having something similar; hope to see it in person sometime.....
our next Model A has arrived.....
Chris in WNC is offline   Reply With Quote
Old 01-01-2013, 11:58 AM   #24
bobbycoke
bobbycoke's Avatar
Wink Re: My new Model A pickup
Originally Posted by Flathead View Post
Black Rustoleum and a brush.........good to go.
NO NO NO use Black Rustoleun and one of those 2 inch FOAM ROLLERS much more professional results!!!
bobbycoke is offline   Reply With Quote
Old 01-01-2013, 12:20 PM   #25
Gumpy
Gumpy's Avatar
Very nice cab to start with, its coming together fast happy new year!
"I believe God is managing affairs and that He doesn't need any advice from me. With God in Charge, I believe everything will work out for the best in the end. So what is there to worry about". Quote by Henry Ford
Gumpy is offline   Reply With Quote
Old 01-01-2013, 01:37 PM   #26
George Miller
Hi Chris
I like hot rods, but I also like stock Model A's. I always use original parts when ever I find them. Also like the engine number to match the frame. All my original cars have the engine they were born with. I also would not cut up a good car.
This truck will have a lot of original parts. Most folks would not want the parts that are going to be used. The engine cylinders were rusted bad, it took .188 to clean up. My goal is to build it as cheap as possible.
Yes it will most likely be at a hill climb one day. If it does it will have a hot 4 cylinder.
Old 01-01-2013, 01:42 PM   #27
George Miller
Bill this engine and transmission have factory float-A- motors. That should make it a nice smooth truck.
Old 01-02-2013, 05:01 PM   #28
devoreb
devoreb's Avatar
George,
What color are those floatamotors? Are they left handed?
Bill
devoreb is offline   Reply With Quote
Old 01-02-2013, 07:52 PM   #29
George Miller
Originally Posted by devoreb View Post
George,
Bill
Yes .
Old 02-07-2013, 09:48 AM   #30
George Miller
Up date on truck.
Box after primer.
Old 02-07-2013, 09:55 AM   #31
George Miller
One more of truck after trial fit.
Old 02-07-2013, 10:03 AM   #32
mhsprecher
mhsprecher's Avatar
I like it!
mhsprecher is offline   Reply With Quote
Old 02-07-2013, 10:18 AM   #33
George Miller
Originally Posted by 31ster View Post
Do you have any photos of your frame setup, what rear end etc?
I have a couple. Does not show the Lincoln rear axle, but that is what it is. Had to shorten the torque tube and drive shaft.
Old 02-11-2013, 09:52 AM   #34
George Miller
Here is a picture of the box, it is all done.
Old 02-11-2013, 12:30 PM   #35
PetesPonies
PetesPonies's Avatar
George, tell me you are not using lacquer spot putty??
Pete's Ponies
Mustang RUSToration & Performance
PetesPonies is offline   Reply With Quote
Old 02-11-2013, 01:12 PM   #36
George Miller
Using K36 high build primer. Should be called K36 high price primer. It is kind of pricey since the last time I use it.
I'm not really a body man, do the best I can.
Old 02-11-2013, 01:32 PM   #37
PetesPonies
I'm referring to the red spots on the back of the cab.
Pete's Ponies
Old 02-11-2013, 02:03 PM   #38
George Miller
Yes I did, maybe it was not a good idea. It had some bad rust Pitts from laying on it side for years, before it went to the barn. The gas tank was about half full of mud from laying on it's side. As luck would have it, I had a better tank.
Old 02-11-2013, 02:47 PM   #39
PetesPonies
No one should be using that material anymore. It swells from whatever you put on top of it and it will shrink as it dries out. It causes sand swell scratches to occur after its painted. There are 2K finishing putties that you should use and throw that stuff away
Pete's Ponies
Old 02-11-2013, 03:50 PM   #40
George Miller
Thanks for the advice. Will get some
