Old 07-28-2010, 12:23 PM   #1
1928Pickuppain
1928Pickuppain's Avatar
Default What happened
So I have been driveing my truck all around the town the last couple of days with no problems. When i first got it running it would over heat; then i draned it flushed it put CLR In there for a few hours and then draned and refilled put new fan belt on and no more over heating ran like a champ.
today was my first time taking it to work about 45 miles it started getting hot in town and i figured it was just becouse of all the red lights and it was already a prity hot morining. then i get on the high way and it starts boiling out the cap and spewing on the ground. I let it cool and then got to work were it over heated again. what do you think Happened?
1928Pickuppain is offline   Reply With Quote
Old 07-28-2010, 12:37 PM   #2
Ron in Quincy
Ron in Quincy's Avatar
Default Re: What happened
One thing that will cause this problem is a blown head gasket; check radiator for bubbles in fluid while running engine.
Ron
Ron in Quincy is offline   Reply With Quote
Old 07-28-2010, 12:46 PM   #3
Mitch//pa
blown head gasket caused by a restricted radiator?
Old 07-28-2010, 12:51 PM   #4
middletown
middletown's Avatar
You may be circulating rust and debris that have come loose from water passages as you drive. The flush may have loosened some/all the rust at the bottom of the block that was stuck for years. These can clog the radiator tubes and cause over heating. I had this happen to me after I flushed a system in my brothers Galaxie. We loosened all the garbage and it continued to come loose and repeatedly clog the radiator. We installed a Gano Filter and it cured the problem; after about 6 months the filter was not trapping any more debris so we took it out.
Just an idea,
Joe
http://autocoolantfilter.com/
middletown is offline   Reply With Quote
Old 07-28-2010, 01:08 PM   #5
Dan Baron
Dan Baron's Avatar
Your air mixture on your carb. might be open too much. Turn your choke rod only 1/4 of a turn. The recommended setting should only be a 1/4 turn counterclockwise. I had the same problem and was all set to order a new radiator. The guy at P.V. Antiques told me he would love to sell me one but to try that first. That's all it was for me.
All I want, is a little bit more, than I'm ever going to get!
Dan Baron is offline   Reply With Quote
Old 07-28-2010, 01:26 PM   #6
Charlie Stephens
Is your fan belt tight?
Charlie Stephens
Old 07-28-2010, 01:41 PM   #7
Patrick L.
Patrick L.'s Avatar
Could be several things to look at.. How old is this engine ?? Check for bad head gasket[ pressure/bubbles in coolant and compression check].. Check for plugged radiator.. Where have you been running the spark lever??
Old 07-28-2010, 01:41 PM   #8
Larry Brumfield
Charlie Stephens
Yep, I would also check the belt first and then report back for further instruction if needed.
Gently move the fan a short distance by one of its blades and see if the belt will slip easily in the pulley.
Larry B.
Larry Brumfield is offline   Reply With Quote
Old 07-28-2010, 02:31 PM   #9
1928Pickuppain
It has brand new fan belt super tight had to remove gen pully and still took two of us to get it on. the motor is a 1928 origonal never rebuilt and never taken off the road eather only 1 real owner before me bought it new in 28 drove it till he died but comprestions good and no bubbles or oil in radator so head gasket is still good.
Old 07-28-2010, 02:37 PM   #10
J Franklin
J Franklin's Avatar
Do the flush and back-flush again. make sure you are not running it retarded too much also.
Old 07-28-2010, 04:26 PM   #11
Ron in Quincy
Sounds like your fan belt would be OK if you had a Altenator; Napa has various lengths of 5/8" belts.
On my driving A I use the Napa belt that has cuts on the inside; don't have to over-tighten which puts a lot of strain on the waterpump and generator.
Ron
Old 07-28-2010, 07:07 PM   #12
Larry Brumfield
Sometimes a head gasket can fool you. Try testing it with a load on the engine using the following method:
First, remove the radiator cap and make sure the water level is high enough for you to see it. Then remove the fan belt. Next, have an assistant stand in front of the radiator so he can look at the water and report what he sees.
Next, you get in the car and start the engine. After it warms up good enough to run, push in the clutch, shift into reverse and continue to hold the clutch down. Put your other foot ON THE BRAKE and leave it there! Next, move the throttle lever with your hand and race up the engine a little AND at the same time, let out on the clutch a little like you're trying to back up BUT hold the car back with your foot on the brake. This will put a load on the engine.
Now .... while all this is happening, have your friend observe the water in the radiator for bubbles and/or foaming bubbles. If they are seen, race up the engine a little more (but still hold the car back firmly with the brake) and see if the bubbles increase.
Larry B.
Old 07-28-2010, 09:25 PM   #13
PC/SR
Any engine that has not been rebuilt, my first guess would be radiator and block scale and rust. Ask a radiator shop to at least boil it out, and rod out the tubes if they will. Use plain water and try some Watter Wetter or one of the other similiar products.
PC/SR is offline   Reply With Quote
Old 06-09-2014, 07:35 AM   #14
timmer117
I had a similar problem. I bought an original radiator to replace the two row repro radiator played with the timing and could not get it to stop overheating, before I was going to tear it down to figure out the problem I installed a new leakless water pump. Never overheated since, problem solved.
timmer117 is offline   Reply With Quote
Old 06-09-2014, 08:45 AM   #15
30ccpickup
30ccpickup's Avatar
Summation of above plus one or two:
    1. Lack of water
    2. Lack of oil
    3. Gas mixture too rich
    4. Fan belt loose or slipping
    5. Incorrect spark timing
    6. Brakes not adjusted properly
    7. Water circulation retarded by sediment/grease in radiator.
    8. Excessive carbon deposit on piston heads and combustion chamber
    9. Blown Head Gasket
http://MODELABASICS.com/ How Things Work on a Model "A" Ford
Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles.
30ccpickup is offline   Reply With Quote
Old 06-09-2014, 09:07 AM   #16
Bob Bidonde
Bob Bidonde's Avatar
A head gasket leak is easy to detect by a compression test. Bubbles appearing in the upper radiator tank are not a positive indication of a head gasket leak because the water pump will cavitate and suck air into the cooling system.
Bob Bidonde
Old 06-09-2014, 09:18 AM   #17
christian
christian's Avatar
That's why you are supposed to remove the fan belt first.
1931 Slant Windshield fordor
christian is offline   Reply With Quote
Old 06-09-2014, 09:24 AM   #18
C26Pinelake
Mine was simple so the mechanic said. The spark lever was too far up on the column. Instead of 2/3 up he suggested 2/3 down. Sounds simple but it cured the problem.
Wayne
C26Pinelake is offline   Reply With Quote
