Old 09-20-2012, 10:59 AM   #1
leadpot
leadpot's Avatar
Default How much is too much Oil
Still being a relative newbie have a question about the oil level. Just changed oil on my stock 29. The level is just above (1/8") the "F" mark on the dipstick, is this ok or should I drain a little. Don't want to do any damage.
Thanks, Leadpot
leadpot is offline   Reply With Quote
Old 09-20-2012, 11:11 AM   #2
C26Pinelake
Default Re: How much is too much Oil
When I bought my first A it was from a Model A mechanic that was in the business all his life. One of his cautions was do not overfill the oil as it is just about as bad as not enough. He said as soon as you go beyond the full you are asking for trouble !
For what it is worth !
Wayne
C26Pinelake is offline   Reply With Quote
Old 09-20-2012, 11:14 AM   #3
1928Pickuppain
1928Pickuppain's Avatar
i Wouldent worrie about it. I never do and i dont have a problem it will drip out in no time hahaha
1928Pickuppain is offline   Reply With Quote
Old 09-20-2012, 11:15 AM   #4
Tacoma Bob
Tacoma Bob's Avatar
My understanding too. At the advice of many in our club, when I do an oil change I replace with 4.5 quarts.
Tacoma Bob is offline   Reply With Quote
Old 09-20-2012, 12:19 PM   #5
Louis
Thanks, Leadpot
Mine does leak if I service it to full on the dip stick, when I change my oil I leave it at 1/2 qt. low and it only leak's a few drop's after a 30 mile ride.
Don't know if my dip stick is org. or not, when I change the oil I only put in 4 qt's, then after eng. warm up bring it up to 1/2 qt. low mark.
Leadpipe, If it were me I would drain out about a 1/2 qt. or you can just wipe down the oil pan after each drive untill the oil level drops to aprox. 1/2 qt. low. JMO.
I also do not over fill the trans. and rear end, if I can touch the oil with my index finger, I leave it alone.
I've suffered a great many Catastrophe's in my life.....most of them never Happened.
Louis is offline   Reply With Quote
Old 09-20-2012, 03:49 PM   #6
Bob/Kansas City
Bob/Kansas City's Avatar
The part that drips out on the floor through hole in the flywheel housing is the too much part!
Fill it so it is about a half quart low on the dip stick and that should save you from cleaning up after it when it marks it's territory.
Bob/Kansas City is offline   Reply With Quote
Old 09-20-2012, 04:58 PM   #7
Clem Clement
Clem Clement's Avatar
I have several dip sticks, all with different line locations for full. I don't know of anyting that will get damaged with a higher oil level.
Old 09-20-2012, 05:18 PM   #8
30ccpickup
30ccpickup's Avatar
Thanks, Leadpot
Drain a little, it is a good excuse to spend some time with it. Plus there will be no worry.
Paul
http://MODELABASICS.com/ How Things Work on a Model "A" Ford
Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles.
30ccpickup is offline   Reply With Quote
Old 09-20-2012, 05:35 PM   #9
raprice
I wouldn't worry too much if the oil level is only 1/8 inch above the full mark.
Don't lose any sleep over it.
Rog
raprice is offline   Reply With Quote
Old 09-20-2012, 06:33 PM   #10
leadpot
leadpot's Avatar
Thanks for the advice - went ahead & drained it to just below the "F" mark. Was no big deal to drain some down - was too tired (being lazy) before & thought it will be ok but changed my mind later.
Thanks again, Leadpot
Old 09-20-2012, 07:27 PM   #11
glenn in camino
glenn in camino's Avatar
I put 5 quarts in cause I have a filter. It's slightly above the fill mark.
