Old 08-23-2012, 01:58 PM   #1
TinCup
TinCup's Avatar
Default Diamond Block Project
Picked up a couple of diamond block pump motors in western Oklahoma and just started tearing the first one down. Looks like a project for sure. Appears # 4 piston broke at the pin. Good news is cylinder wall doesn't appear damaged. No marks on the piston top so it appears to be a standard bore. Rod is marked 120 not sure what that means. The oil channel in the valve chamber appears to be the only rust damage.
TinCup is offline   Reply With Quote
Old 08-23-2012, 03:58 PM   #2
just plain bill
just plain bill's Avatar
Default Re: Diamond Block Project
Did you mike the rod throw to see what size it is?
just plain bill is offline   Reply With Quote
Old 08-24-2012, 09:44 AM   #3
TinCup
TinCup's Avatar
I don't have the tools to mic the rod or piston. I will take them to one of my buddies who does.
Old 12-04-2012, 05:05 PM   #4
TinCup
TinCup's Avatar
Well we got the project finished up today and I thought I would post a few pictures and a video of the motor running. Ended up having to bore the cylinders to 80 over and deck the block. We added new pistons and rings but kept the mains and rods as they were as we felt their was sufficient bearing for a motor that will be used as a spare and a run-up motor. Thanks to my good friend Bob Bordwine here in OKC for all the help and expert advice.
First Run Video
Old 12-05-2012, 08:30 AM   #5
ctlikon0712
ctlikon0712's Avatar
Looks great, glad it all worked out.
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
Old 12-05-2012, 08:44 AM   #6
Farrell In Vancouver
Farrell In Vancouver's Avatar
What did you use to get the babbit all shine up? It looks and sounds like a runner now......great job!
Farrell In Vancouver is offline   Reply With Quote
Old 12-05-2012, 09:15 AM   #7
TinCup
TinCup's Avatar
Farrell, Just cleaned the motor with pressure washer. The Babbitt looked like that afterwards.
Old 12-05-2012, 11:10 AM   #8
Rowdy
I wish I would have gotten that lucky with one of my diamond blocks. The standard bore block had no shims left in the main and was worn to the piont it was time for new babbit. The scond one was a victom of a really poor babbit job with a broken up rear main and thrust surface. The crank was also damaged at some point as it had a deep mark between 3 and 4 with the crank bent .012. The third had the center main busted up. One more left to look at some point. I have a different engine on thbe stand that needs a valve job and re-assembly and it should be fine for a backup engine. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 12-18-2012, 11:46 AM   #9
TinCup
TinCup's Avatar
I brought the motor back to the shop today. We only had one problem and that was one of the old W-10 plugs I was bad and it was missing. My buddy Bob replaced them all with W16Y's and that took care of it. Now I just have to carve out some time to put it in the coupe and get started on rebuilding the motor in it.
Old 12-18-2012, 01:31 PM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
Looks good, but I believe the oil return pipe needs be be turned end for end.
Old 12-18-2012, 02:11 PM   #11
TinCup
TinCup's Avatar
Yup, Tom you caught me. We didn't notice it until we were loading it up.
