Old 07-18-2012, 11:13 AM   #1
AlanD
Default Disassembling speedometer gear "turtle"
This is for those who are trying to figure out (as I was) how to disassemble and rebuild the speedometer driven gear that mounts on the torque tube, otherwise known as the "turtle."
I kept reading about removing the end cap and some said to put a small hole in it, to which a screw could be threaded and used as a pulling point. Looking at mine, I saw there was already a small hole so I put a screw in and removed the end cap,
(see pic 1 below). This doesn't help because the shaft won't come out this way.
Then the Lord told me to try the other end. I thought I was breaking it at first, but it was actually coming out. Gently pry around this with a screw driver and the end comes off, (see pic 2 and 3 below).
Now the shaft can come out and the gear removed and replaced.
AlanD is offline   Reply With Quote
Old 07-18-2012, 11:15 AM   #2
jrapose
jrapose's Avatar
Default Re: Disassembling speedometer gear "turtle"
Thanks Alan
I was looking at that last night....thanks for the tip.
Joel
jrapose is offline   Reply With Quote
Old 07-18-2012, 05:21 PM   #3
1931 flamingo
1931 flamingo's Avatar
AlanD: That's what I was hoping you'd figure out when i gave you the parts description from snyder's. I've never had to take one apart myself. Thanks for posting for EVERYONE to see.
Paul in CT
Old 07-18-2012, 05:29 PM   #4
Harold
Thanks for the update. I'm going to have to take mine apart, so now I know exactly how to do it. Thanks, Harold
Harold is offline   Reply With Quote
Old 07-18-2012, 07:24 PM   #5
spdway1
spdway1's Avatar
Flamingo, You czn practice on mine! Speedo STILL bouncing.
spdway1 is offline   Reply With Quote
Old 07-18-2012, 09:39 PM   #6
1931 flamingo
PM sent
Paul
Old 07-30-2012, 09:10 AM   #7
AlanD
Update: Fixed!
With a new shaft and gear I rebuilt the turtle. That gear is tight going on the shaft so if you do this be prepared for some difficulty (especially if you have pre-greased it, I should have waited).
Now the speedometer is working steady - no more bouncing! Yay!
But the speedometer reads about 5 mph slower than I am driving. I was using a neat iphone app to give me a relative measure of my actual speed.
Old 07-30-2012, 09:54 AM   #8
green30coupe
green30coupe's Avatar
AlanD,
What app did you use to measure speed? I have used my Garmin GPS to check speed, but an app for iPhone would be more convenient.
Ed
green30coupe is offline   Reply With Quote
Old 07-30-2012, 11:19 AM   #9
AlanD
It's a free app called Hans Schneider Speedometer.
I checked it in my modern car and it's usually accurate to + 1 mph.
Old 07-30-2012, 12:29 PM   #10
green30coupe
Thanks, AlanD. I downloaded it and will try it out soon.
Ed
Old 02-14-2016, 03:22 PM   #11
pklarkin
pklarkin's Avatar
Smile Re: Disassembling speedometer gear "turtle"
Thank you Alan! This is the only reference I found anywhere on the internet.
pklarkin is offline   Reply With Quote
Old 02-15-2016, 01:32 AM   #12
duke36
just rebuilt one as well using an 18 tooth gear , not the std 19 ('31) to accommodate slow speedo. Repro gear is smaller and may have some slippage at torque tube speedo drivegear with paper gasket installed. May go back to the 19 tooth. Had to replace the end cap available from the vendors. There is a traffic app for I phones called Waze that has mph shown when the app is opened.
Old 02-15-2016, 12:04 PM   #13
VFRhugh
VFRhugh's Avatar
I dissembled the speedometer on my 1930 because it was reading slow and neither odometer worked. Managed to get the trip working and adjusted the calibration plate to read correctly. Maybe I was lucky but the speed matches my GPS.
Used this for directions.
http://www.modelahouse.com/tech/spee...r/fischer.html
VFRhugh is offline   Reply With Quote
Old 02-15-2016, 01:03 PM   #14
Brentwood Bob
Thanks for the education. Looks to me that total disassembly would give the best outcome since you can clean the housing real good.
Bob
Brentwood Bob is offline   Reply With Quote
