Old 05-03-2012, 04:57 AM   #1
46ford
46ford's Avatar
Default ID this engine
24-stud, large water jacket openings. 3-bolt timing cover. '38 to '42 90 hp? Need to get head gaskets.
Do headgaskets go smooth side up or crimped side up?
46ford is offline   Reply With Quote
Old 05-03-2012, 09:31 AM   #2
Bill Steiner
Default Re: ID this engine
I always put the crimp side up. Just my opinion, but i think it is easier to smooth off the head than the block at a later time. Bill
Bill Steiner is offline   Reply With Quote
Old 05-03-2012, 01:18 PM   #3
Bruce Lancaster
Also, Ford essentially obsoleted the keystone gaskets you pictured. For better cooling in the keystone engines they recommended '46-8 round hole gaskets and minor redrilling on the center row of holes in early heads. Info is covered in the '37-48 engine manual, I summarized the simple work in an older post:
Got it...Ford V8 overhaul manual, '37--48:
Look at central vertical row: Topmost hole gets drilled to 3/4", skip one, third from top goes to 5/8", next two nada. All done!
Late gaskets are the same R and L but have a front and back due to some small hole size differences...so because of this, one goes crimp up, the other crimp down!
