Old 01-15-2012, 09:30 PM   #1
JBohannon
Default Model A oil leak
Well I just started my 29 Model A for the first time and although it never leaked oil on my garage when I started it for the first time it darn near poured oil from between the pan and flywheel housing. Is it the seal. How hard to replace. I am a newbie.
JBohannon is offline   Reply With Quote
Old 01-15-2012, 10:11 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Model A oil leak
Did you overfill oil> 5qts total. I/2 usually stays in pan when drained.Refill with 4qts.?
www.whidbeymodelaclub.com
Old 01-16-2012, 02:58 AM   #3
Mike V. Florida
Mike V. Florida's Avatar
My first guess is the oil pan gasket slipped when putting it on.
Old 01-16-2012, 02:23 PM   #4
Frank Miller
Frank Miller's Avatar
Did you have the motor out? I have heard of people forgetting the gasket between the engine and flywheel cover.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 01-16-2012, 10:14 PM   #5
columbiA
Since its not leaking out the hole on bottom of F-wheel hsg,it likely is leaking from either the rear of the pan gasket or a poor or no gasket between block & FW hsg.Clean off the area with some brake cleaner spray,fire up the engine & see where its leaking.If leaking from back of camshaft,engine will need to come out.If you need to replace gasket,remember to add shims equal to gasket thickness between top ears on FW hsg& block.
columbiA is offline   Reply With Quote
Old 01-17-2012, 12:00 AM   #6
Benson
JB,
Stock engine has no rear crankshaft seal ... just a slinger and drain tube.
This might help:
http://antiqueenginerebuilding.com/REARMAINLEAK.html
Old 01-17-2012, 06:03 AM   #7
Pepsi Mechanic
Pepsi Mechanic's Avatar
I would run the engine for a bit .. let the oil level find itself .. it will probably stop leaking ... I run 4.5 quarts in our truck ( just below the full mark ) and it is fine .. anymore and she runs out the back like yours ..As Benson said , there is no rear oil seal on a stock engine
Pepsi Mechanic is offline   Reply With Quote
Old 02-02-2012, 11:34 AM   #8
sukhoi
sukhoi's Avatar
Might be the gasket is missing between the F/W housing and engine.
sukhoi is offline   Reply With Quote
Old 02-02-2012, 01:48 PM   #9
V4F
V4F's Avatar
the gasket they are talking about seals the rear of the cam . very important & will pour oil till you have none ................ steve
V4f
V4F is offline   Reply With Quote
