Old 01-26-2012, 07:45 PM   #1
old skool
Default over drive system
Hello,
There is a guy selling over drive systems for a stock model A on ebay for about $1650.00. You have to send him a good tube. Anyone out there using one? Are they any good? Any feedback?
Thanks,
Marty
old skool is offline   Reply With Quote
Old 01-26-2012, 08:06 PM   #2
AL in NY
AL in NY's Avatar
Default Re: over drive system
Is this the unit you are referring to??????
AL in NY
AL in NY is offline   Reply With Quote
Old 01-26-2012, 10:31 PM   #3
Herb Concord Ca
If it looks like the one Al in NY's photo. That's a LayCock de Normanville overdrive, use in European cars before 5-speeds came into use.
It's a good unit, and IMHO it's the best way to go!
I have one, it's now in it's second model A, have used it for 10 years, currently in my S/W Town sedan.
It's operated by a toggle switch, no mechnical linkage to take up floor space!
Price seems a little high, but who knows.
Regards
herb
Herb Concord Ca is offline   Reply With Quote
Old 01-26-2012, 11:15 PM   #4
b ramsey
i have a volvo unit, and think its the greatest thing ever....
b ramsey is offline   Reply With Quote
Old 01-27-2012, 12:20 AM   #5
pat in Santa Cruz
pat in Santa Cruz's Avatar
easily as important as the type of overdrive, is the engineering behind the adaption and its execution. I've seen these with really crappy welding and poorly designed reinforcement, so that the torque tube sags and the drive line fails. I've also seen them done excellently from Rich Little.
Also, since these units are from used vehicles, is the OD rebuilt? What is the name of the seller and builder? I cannot tell any of that from this description. caveat emptor
pat in Santa Cruz is offline   Reply With Quote
Old 01-27-2012, 09:29 AM   #6
Jason in TX
Jason in TX's Avatar
I can't speak for that seller, but I love my Volvo overdrive!
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 01-27-2012, 09:36 AM   #7
John LaVoy
John LaVoy's Avatar
I agree with Pat talk to someone who has one of the units they made, the Laycock is good, but the welding and fabrication has to be good too.
John LaVoy is offline   Reply With Quote
Old 01-27-2012, 09:42 AM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
My friend just bought the same LayCock de Normanville overdrive to install in his 1929 Stutz. If I was going to install an overdrive that's the unit I'd like to use also.
My friend with the Stutz bought a set of 3.27 ring and pinion gears from Bert's for his 31 widebed, and I can't wait to drive it with them. Still waiting on the bodyman to finish painting the box for his widebed. The painter has only had it for 10 years!
Old 01-27-2012, 11:27 AM   #9
John LaVoy
John LaVoy's Avatar
Tom,
The painter must be using the really slow drying paint! LOL
Old 01-27-2012, 05:41 PM   #10
maximum od
Hi i think your reffering to my Overdrives on ebay,im the guy building them. GLENN
maximum od is offline   Reply With Quote
Old 01-27-2012, 05:51 PM   #11
maximum od
Yes i rebuild them and i have a dyno setup to test them. GLENN
Old 01-27-2012, 08:43 PM   #12
old skool
Hello,
Yes, the one in the photo is the one I am refering to. Looks like the maker has joined in.
I had some bad experiences on ebay and I am always a little "uneasy" about getting certain things on there (esp when it cost a good bit of money).
Marty
Old 01-27-2012, 08:47 PM   #13
maximum od
yes, they are volvo,yes the tubes are machined before they are tig welded,No need to balance.Yes 6 month unlimited mileage warranty.
Ive got all the parts i need to rebuild them. GLENN
Old 01-27-2012, 08:54 PM   #14
maximum od
Well ive been rebuilding GV units for years. and For the Hot rod guys with 800hp+, ive had alot of guys ask me to build custom one offs.So now
its time to help out the guys with the torque tubes.Ive got a web site but
im not sure i can post it here on the form. GLENN
Old 01-27-2012, 10:07 PM   #15
pat in Santa Cruz
I have a Laycock D'Normanville in my sedan, and it is my preferred OD. Maximum OD, could you show some detailed photos of the connection to the torque tube, please? I don't think there is a rule against posting the website, My guess is its here:
http://www.maximum--overdrive.com/products.html
Old 01-27-2012, 11:28 PM   #16
maximum od
Pat
yes thats its the site. actually your in santa cruz,im very close,im in Aromas.but to answer your question,the first one i used a splined coupler
that i had made,but now im using a coupler with a 1 inch blind hole 1/4 keyway
and a 3/8 cross drilled hole and a hardened dowel pin.I will have to find the pictures.
Old 01-27-2012, 11:28 PM   #17
azmodela
At that price why not go with the Mitchell for a few $$ more? It's new, it's fully mechanical, and parts/rebuild are available!
azmodela is offline   Reply With Quote
Old 01-27-2012, 11:43 PM   #18
maximum od
yeap! a few hudred more.and when i rebuild them there like new .theres pro`s and cons for both. one of the best features about the Laycock is full power shifts you dont have to back off the gas at all
Old 01-27-2012, 11:45 PM   #19
Jason in TX
I usually push in the clutch when I shift mine. Is that not needed?
Old 01-27-2012, 11:46 PM   #20
b ramsey
it shifts witha toggle switch, feels like an automatic trans when it shifts. parts are avail, very common at local yards, i found five of them in one location. and cheaper. thats why.
