Old 01-05-2012, 11:31 PM   #1
C26Pinelake
Thumbs down How much work to replace rear main seal in motor
Mechanic says come spring I should look at new rear main seal. Does the motor have to come out ? Is there an easy way ? Is there different kinds of seals ? how many hours labor ?
Thanks wayne
C26Pinelake is offline   Reply With Quote
Old 01-06-2012, 12:12 AM   #2
pat in Santa Cruz
pat in Santa Cruz's Avatar
Default Re: How much work to replace rear main seal in motor
without any further description of your particular engine seal , its hard to say. A Stock A has no rear "seal" it is just a slinger with a drainage system. There are some modern seals that can be added after market, many of which have problems. Without knowing what you have, I could not say much, except in many cases of repair to after market seals, the engine does have to come out. However, rear main leaks are a common problem, and there are several causes, some of which require engine removal and some not. Proper diagnosis is imperative before undertaking a remedy. Read this list of rear main leak causes and determine what your problem is, then you will have enough info to know if the engine must come out.
http://www.antiqueenginerebuilding.c...RMAINLEAK.html
pat in Santa Cruz is offline   Reply With Quote
Old 01-06-2012, 08:13 AM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Well said Pat!!
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 01-06-2012, 09:07 AM   #4
2935ford
2935ford's Avatar
Great info on that site!
Thanks Pat.
2935ford is offline   Reply With Quote
Old 01-06-2012, 09:51 AM   #5
C26Pinelake
Thank you, you have been most helpful.
Regards, Wayne
