Old 12-27-2011, 07:08 PM   #1
dfish2931nc
dfish2931nc's Avatar
Send a message via ICQ to dfish2931nc
Default lug nuts for 16" wheels
Can I use the model A lug nuts when I install 16" wheels? If not, will modern lug nuts do the job? Thanks in advance.
dfish2931nc is offline   Reply With Quote
Old 12-27-2011, 08:25 PM   #2
James Rogers
James Rogers's Avatar
Default Re: lug nuts for 16" wheels
Yes to both.
James Rogers is offline   Reply With Quote
Old 12-27-2011, 08:28 PM   #3
Vanspeed
Vanspeed's Avatar
I use the stock A lugs on all my 16 inch wheels. Mostly because I love the way they look even if they are under a hub cap.
Respecting and Resurrecting Ford Model A's.
Vanspeed is offline   Reply With Quote
Old 12-27-2011, 08:31 PM   #4
V4F
V4F's Avatar
been using stock nuts for like 8-9 yrs ............. steve
V4f
V4F is offline   Reply With Quote
Old 12-27-2011, 10:51 PM   #5
Slseacrist
I was told that the acorn were not advisable as the internal depth of the nut and the stud length were too tight to insure a snug fit over 16 inch rims. With that said I run them for a year, before I replaced them with standard. This was more out of need for the acorns of my other A then concern the nuts were not tight.
Slseacrist is offline   Reply With Quote
Old 12-29-2011, 11:41 AM   #6
dfish2931nc
Thanks Guys. Saved me a few bucks
Old 12-29-2011, 12:34 PM   #7
Charlie Stephens
Shouldnt be a problem unless someone used longer than standard lug bolts which is a possibility since there wouldn't be a problem using the longer lug bolts with the standard nuts that are open on both sides.
Charlie Stephens
