Old 04-08-2026, 12:37 PM   #1
goodcar
Default No Foot Starter Coversion
I'd appreciate some opinions on the NO Foot Starter conversion $149. Also just using a 6-volt solenoid instead. Thanks
goodcar is offline   Reply With Quote
Old 04-08-2026, 12:42 PM   #2
Y-Blockhead
Y-Blockhead's Avatar
Default Re: No Foot Starter Coversion
Nothing real special or new about a No Foot Starter conversion. I have a old version someplace, I will post a picture if I find it. It just uses a regular 6v solenoid and a mounting bracket to mount to the starter. $149 is way to expensive, IMO.
Old 04-08-2026, 01:55 PM   #3
1955cj5
1955cj5's Avatar
Our ccpu had a push button start.......way ahead of it's time! Downside is the hole...
Oh, and a solenoid. 6 volt.
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 04-08-2026, 02:22 PM   #4
Jim/GA
Jim/GA's Avatar
You could also look for an "up start" lever that mounts to the steering column. You pull up on the lever and the rod pushes down on the starter switch for you. Way easier than finding the starter switch button with your right foot.
Jim Cannon
"Have a Model A day!"
Old 04-08-2026, 02:32 PM   #5
CarlG
CarlG's Avatar
I have a key start on my Pickup. Bought a kit from a guy near Ft.Worth, TX.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 04-08-2026, 04:26 PM   #6
goodcar
I liked the idea of the upstart lever and looked for one some time ago but couldn't find one. Need to look again I guess.
Old 04-08-2026, 06:56 PM   #7
Bigsnapper43
I'm 6'4" I had to move the seat back 2" in my Vicky. I could get about 1 year out of a starter switch. They were worn wobbly. At a local swap meet I found an old kit to add push button start to a 1937 Plymouth. This was the best $10 bucks I ever spent. It bolted right on, ran the wire to a button under the windshield pannel. That was 5 years ago.
Bigsnapper43 is offline   Reply With Quote
Old 04-08-2026, 08:48 PM   #8
Trapdoor2
Trapdoor2's Avatar
LOL, until I moved the seat back in the Coupe, I used my cane. A little fiddly but the rubber tip stayed on the starter button nicely. I sketched out both a lever system for the steering column and a cable-operated push button for the dash...but simply moving the seat back 3" suddenly allowed my big foot to reach the button comfortably.
'31 Ford Deluxe Coupe "The Green Hornet"
Trapdoor2 is offline   Reply With Quote
Old 04-09-2026, 02:19 PM   #9
Russell Reay
Russell Reay's Avatar
I didn't like the idea of having to multi-articulate my right ankle, so I installed a solenoid. This isn't so complex that it needs an expensive kit
Russell Reay is offline   Reply With Quote
Old 04-09-2026, 02:35 PM   #10
ModelA29
ModelA29's Avatar
I got one of the kits at an estate sale $40. I think the 3 pole solenoid is a Ford tractor item.
https://www.yesterdaystractors.com/N...yABEgKZW_D_BwE
ModelA29 is offline   Reply With Quote
Old 04-09-2026, 05:38 PM   #11
The Master Cylinder
The Master Cylinder's Avatar
Most 6 volt solenoids are 3 pole. 12 volt ones are 4 pole in order to bypass the ballast resistor to supply full 12 volts to the coil for starting.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 04-09-2026, 10:50 PM   #12
The Old Guy
Is that a picture of the ignition switch it had in it?
The Old Guy is offline   Reply With Quote
