Old 03-18-2026, 04:52 AM   #1
flathead48
Default Wheel cylinder lube
Back in the 60s NAPA used to sell little tubes of a lube for master cylinders & wheel cylinders to be used when rebuilding them. Does anyone know of a good
Replacement ? Thank you, Rick
flathead48 is offline   Reply With Quote
Old 03-18-2026, 07:10 AM   #2
marko39
Default Re: Wheel cylinder lube
You can lube everything with clean brake fluid.
marko39 is offline   Reply With Quote
Old 03-18-2026, 09:41 AM   #3
V8 Bob
V8 Bob's Avatar
The only time a "Lube" may be needed is on disc caliper piston seals. As marko39 stated, clean brake fluid is all that's needed for master/wheel cylinder rebuilding.
Old 03-18-2026, 02:00 PM   #4
John R
Raybestos used to sell an assembly fluid for wheel cylinders. I got some a few years ago. Very useful when rebuilding cylinders and then not using them right away.
Those who do not move do not die, but are they not already dead?
John R is offline   Reply With Quote
Old 03-18-2026, 02:03 PM   #5
flathead48
Thanks to all for your replies
