Often times we get requests to install a sound deadening material (Dynamat) and foil insulation behind the upholstery to help with combatting noise and heat. The costs to install Dynamat is beyond expensive these days. Can anyone recommend a product they have used that they feel is equal to or better than the 18"x32" sheets that Dynamat sells?
What part is expensive, the materials or labor to install them? The sheets/material cost seems reasonable to me.
I insolated my garage with a product just like this. It was a bubble wrap with foil meant to be used in chicken houses where the humidity is high. It was cheap and made in America. Sorry I don't remember a name. Maybe check with a pole barn installer?
Brent,
I have been using "FatMat" on the last 3 cars I did. I buy it off of ebay & feel it is just as good as Dynamat without paying for the name. God Bless & Merry Christmas Bill https://www.jalopyjournal.com/forum/...closed.614419/
"Jealousy is a Sad Pathetic Character Trait Generally Held By The Lazy, Immoral Dregs of Society" 1955 Chevy Altered W.B. Gasser 1955 Nash Amb. Cust. Lemans 1957 T-Bird 1964 Pontiac Grand Prix 2 DR HT 1966 Pontiac Catalina Conv 1966 AMC Ambassador DPL 2 DR HT 1966 AMC Ambassador Cust 2DR HT 1967 AMC Marlin 1967 Toronado 1973 Chevy Nova Full Chassis Car 1992 Jag XJS Conv 1992 Jag XJS 2 DR Coupe 2007 Cadillac XLR-V Supercharged Roadster 2008 Southern Customs Avalanche |
#5 | |
They sell top quality sound deadening and heat reducing materials. Check them out. No, I have no affiliation to them other than I bought both material types to help with noise and heat in the cab of my John Deere mower. |
#6 | |
I've got this stuff in a few cars including my '31 truck. It is top shelf for sure:
https://www.designengineering.com/ Great for heat and sound. If you want to call them, ask for Mike, you'll get personal service and a TON of knowledge. |
#8 | |
Try these - you can figure out the sq in cost since they are different sizes. https://www.homedepot.com/pep/39-4-i...CABEgKFRvD_BwE https://www.summitracing.com/parts/r...iABEgK6cPD_BwE |
What about 3M body Schultz or equivalent? I’ve used it before quick and reasonable.
Downside is if you want it gone. It’s basically a hardening undercoat |
#10 | |
I have also used it around trans lines, fuel lines & starter harnesses that are close to exhaust manifolds/headers. God Bless Bill https://www.jalopyjournal.com/forum/...closed.614419/
I go to lowes and buy the roll of air duct insulation. It's self adhesive with a silver backing.
I've used it on about 10 Model As and my VW DC. It's ez to work with and it works. |
Noise & Heat Reduction.pdfThis is the sound damping and thermal insulation I put into my Victoria.
Bob Bidonde |
#13 |
Here is the article I wrote for the above Post 12.
Bob Bidonde |
#14 |
Great article Bob.
I have been investigating this for my '30 Tudor. Courtesy of Google AI, sound deadening (soundproofing) effectiveness is primarily determined by four key factors: mass/density, decoupling, absorption, and sealing air gaps. I googled "What are the factors that affect sound deadening" and the answer seems consistent with my knowledge in this area. Regarding the mass factor, I have found plenty of cheaper 80mil Butyl sound deadening products on Amazon that are probably good enough for a Model A. The heavier Butyl rubber products would work for the inside of the vehicle doors and panels and other products would probably work well for the floors (waterproof, closed cell foam with heat reflective backing). Above my muffler I have already installed 1/8" Aluminum sheets underneath the floor boards to reflect that heat. |
#15 |
I can't find that type on the Lowe's website. Can you post the SKU number or more info?
#16 |
I've used a combination of Dynamat and Roadkill. Roadkill seems to work just as well and is less expensive than Dynamat.
#17 |
This thread actually reminded me that I needed to reorder some! This is what I use.
https://www.ebay.com/itm/225832559507 Will be doing the 67 Marlin probably next week & then the 67 Toro as time permits. God Bless Bill https://www.jalopyjournal.com/forum/...closed.614419/
#18 | |
#19 |
You can get rolls of this at Lowe's or Home Depot. I glued it in the side panels of my Tudor without a lot of fuss. I also insulated the interior of a 51 DeSoto with it. Black car with a huge top. It definitely made it cooler inside afterwards!
Steve, Proud owner of 28 Fordor, been in family since 63 30 Tudor 31 S/W Town Sedan Skyline Chapter MAFCA, MARC |
#20 |
Lowe's stk 28929 made by Frost King
Duct insulation $27.00 |
