Who is the current "go-to" guy for lever shock rebuilding? I've seen the name Andy Falandes highly recommended several times, is he still actively doing this? One front shock on my '36 pickup is completely shot and has basically no resistance to motion.
Also, is it the shock/lever arm that actually restrains the front suspension at full droop? I never thought about it before, but I notice the one bad shock's lever arm extends down much further than the other side Adam
1936 pickup, stock, black 1965 Mustang coupe 289/4bbl, black/red 1971 Alfa Romeo GTV 1750 coupe, dark red/tan 1970 911E 2.2 litre dark blue/black 1968 BMW R50/2 US, black (m'cycle) 1967 Triumph TR6R , sea foam/cream (m'cycle) 2022 Royal Enfield Interceptor 650 red (m'cycle) 1974 Honda CB750 red (m'cycle) 2000 Kawasaki W650 blue/silver (m'cycle) |
Just finished my 34 front shock , what service , fast turn around and awesome work ! What an asset to the hobby , last time I dealt with apple hydraulics , what a mess that was , sent same shock back 5 times , and it still leaks , never ever again .
I had Andy do all 4 of my shocks, nice job, quick turnaround, great communication.
Super Moderator
Andy is my guy as well. Recently did a set for a '36 of mine.
Apple? Stay far away. How that place remains in business is beyond my imagination.
Any thoughts on my second question, as to what constrains the front suspension on a '36 (or any similar transverse spring front end) at full droop? If it is, in fact, that shock lever arm/dogbone link, it seems to me that would put a lot of stress on the internals of the shock after years of dropping a wheel into potholes-but I don't see what else limits the movement. Adam
#7 | |
Super Moderator
The spring keeps the suspension within a designed height (+/-) specification.
OK that makes sense. I think my issue is that the passenger side of the spring has lost it's arch, allowing the shock on that side to go beyond its limit-that's the shock that has failed. At this point I'm awaiting a new (stock) spring from Eaton spring, and sending the bad shock to Andy Falandes for a rebuild, if possible-if the shock is beyond repair, then he will try to find a good core for me in his stash. Adam
