Old 10-07-2025, 10:10 AM   #1
Gene's 40
Default '40 tail light bulbs OEM 6V to LED Conversion
Do I need to make any mods to convert to LED tail lights ? What are sources for LED bulbs ?
Thanks in advance !
Gene Talley
Hixson. TN
Gene's 40 is offline   Reply With Quote
Old 10-07-2025, 12:30 PM   #2
Proartguy
Default Re: '40 tail light bulbs OEM 6V to LED Conversion
I got 6 volt positive ground ones from this company:
Www.ledlight.com
Proartguy is offline   Reply With Quote
Old 10-07-2025, 07:01 PM   #3
farmertom
farmertom's Avatar
Www.ledlight.com
yea me too. and 6volt dash bulbs. Tom.
farmertom is offline   Reply With Quote
Old 10-08-2025, 09:00 AM   #4
Planojc
Planojc's Avatar
Do a search on amazon. Just make sure of the correct Bayonet base, whether it is single or dual contact and of the locking tabs are offset or parallel. Also make sure they are non polarity.
Planojc is online now   Reply With Quote
Old 10-08-2025, 02:59 PM   #5
Gene's 40
Thanks all for the advice !
Old 10-08-2025, 04:28 PM   #6
hueyhoolihan
might want to take notice of their overall length too. i bought a set (for the front) that were too long...very disappointed as they tested out well enough and then when putting on the lenses, the you-know-what hit the fan...
can't tell you how much money i've spent and wasted. about half the time. on LED dash bulbs, LED turn signal bulbs, LED tail lights, and LED headlight bulbs over the years, but it's a lot! i keep on roll'n sevens!
hueyhoolihan is offline   Reply With Quote
Old 10-09-2025, 12:41 AM   #7
dean333
dean333's Avatar
Send a message via Yahoo to dean333
I had the same problem trying to put them in the cowl lamps on my 33. They were too long and hit the lens.
Tim Carlig
dean333 is offline   Reply With Quote
Old 10-09-2025, 07:07 PM   #8
JayChicago
JayChicago's Avatar
Here are pics of my '40 comparing incandescent (first pic) to LED (second pic). I could not see a diff. with the LED I got.
The '40 has the additional problem that the taillight lense faces the sky.
Old 10-09-2025, 07:18 PM   #9
petehoovie
petehoovie's Avatar
Old 10-09-2025, 07:33 PM   #10
The Art Doctor
The Art Doctor's Avatar
I agree with Jay, I do not think LED's are any better. They tend to send out light in only one direction while an 1157 style bulb is nearly spherical in light production. The biggest improvement I have seen in old car tail lights comes from painting the housings white inside combined with a spherical light source to brightly light up all that white paint and reflect it on through the red glass lens.
The Art Doctor is offline   Reply With Quote
Old 10-09-2025, 09:55 PM   #11
hueyhoolihan
there are some LED bulbs that are purposely made to match the luminosity of the incandescent bulbs that they are intended to replace. no question...
Old 10-10-2025, 10:07 AM   #12
Planojc
Planojc's Avatar
On my 35, I soldered wires to the side of the bulb sockets and ran them to a good ground on the frame. Also painted the inside white.
Old 10-10-2025, 12:30 PM   #13
Proartguy
The main advantage I found with LEDs is fewer amps draw, especially with brake lights. They are not always brighter. It depends on the color and density of the lens.
Old 10-10-2025, 01:08 PM   #14
40cpe
40cpe's Avatar
I found that the lenses with the led bulbs that were made in the lenses were most visible. there are several suppliers of this type.
Old 10-10-2025, 01:14 PM   #15
petehoovie
petehoovie's Avatar
Old 10-10-2025, 02:47 PM   #16
JayChicago
JayChicago's Avatar
Problem with those is, you can spot them twenty feet away as a not-correct aftermarket item. That would not bother some of us; function is more important. But my car is original as I can keep it. It does bother me.
Old 10-10-2025, 03:10 PM   #17
petehoovie
petehoovie's Avatar
Old 10-18-2025, 08:03 PM   #18
Proartguy
After posting on this thread I took a look and compared both styles and thought the incandescent bulbs, with the housings painted flat white, look brighter on the brake lights.
Old 10-19-2025, 05:31 AM   #19
glennpm
glennpm's Avatar
Not 6 volt but for my 12V negative ground, I'm very happy with my formed LED lights shown below. I tried everything over the years, silver paint, white paint, two 1157 sockets and then from Drake quartz lights to the LEDs
More info and photos in this thread, https://www.fordbarn.com/forum/showt...ght=tail+light
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
