Old 10-06-2025, 10:45 AM   #1
David in San Antonio
David in San Antonio's Avatar
Default Fuel Stabilizer Tests
Do you store your A over the winter? Do you put Marvel Mystery Oil or Sta-bil or Sea-Foam or something else in the gas tank? The linked video should provide endless discussion, controversy, stories of personal experiences, perhaps some outrage, the popping of bubbles and maybe, just maybe some regrets.
https://youtu.be/OHXYWxMkhog?si=73OZ_9W8GZ6AVBR6
Late ‘30 Deluxe "Wretched Roadster"
1931 Slant Windshield Fordor “Earl Gray”
Alamo A’s Club
David in San Antonio is offline   Reply With Quote
Old 10-06-2025, 12:47 PM   #2
32Ford13
Default Re: Fuel Stabilizer Tests
I've had Sta-bil not work as good as Startron. I've been 100% Startron for the past hand full of years and it has never given me grief
32Ford13 is offline   Reply With Quote
Old 10-06-2025, 12:48 PM   #3
ModelA29
ModelA29's Avatar
I use the Sta-bil if It's going to sit for more than a couple months. I never used to but with ethanol in the gas it seems to go bad so much faster.
Try and find a place with pure gas to fill up at before you store it. Still use the additive anyway. Also a full tank will help keep rust from forming on the exposed metal.
ModelA29 is online now   Reply With Quote
Old 10-06-2025, 01:04 PM   #4
LeonardS
Do some research on PRI-G by Power Research Inc. I think it is by far the best stabilizer. Ever wonder how they keep the fuel fresh in those huge storage tanks? Check these guys out. www.priproducts.com
LeonardS is offline   Reply With Quote
Old 10-06-2025, 01:39 PM   #5
BButturff
BButturff's Avatar
First, I don't use gasoline with any amount of ethanol in it in my small engines, outboard motor or Model A. I realize that some of you don't have this option but this has been the key to my never having fuel related problems. Second, I've been using Sta-bil as a medium term (1-year or less) fuel stabilizer for close to 55 years. After 1-year I transfer the gasoline to my regular cars and replace it with fresh.
_______________________
The other Bruce in Minnesota
1931 Model A Closed Cab (Budd) Pickup "Aurora"
Model A Ford Club of America
Lady Slipper A's
"You can't go back and change the beginning,
but you can start where you are and change
the ending." - C.S. Lewis
Last edited by BButturff; 10-06-2025 at 06:56 PM. Reason: Removed duplicate video URL
BButturff is offline   Reply With Quote
Old 10-06-2025, 03:59 PM   #6
Y-Blockhead
Y-Blockhead's Avatar
Thanks for sharing the video. I enjoy watching Project Farm comparisons. Being in So Cal I don't store my Model A in the winter months. I do use Seafoam to help keep the fuel system clean.
My main problem is that the current fuels evaporate out of the Model A vented tank.
Old 10-06-2025, 05:58 PM   #7
nkaminar
nkaminar's Avatar
Where I live it is warm enough in the winter to keep running my Model A. Although some days are too cold or too wet. I keep the battery maintainer connected if I am not going to drive it for a week or more. If I am going to be away for more than a month I will run the carburetor dry and put the car on jack stands to keep the tires from getting flat spots. I don't use any stabilizers in the tank and run gasoline with ethanol but I keep the tank mostly full. My car lives in my garage with a dehumidifier.
Old 10-06-2025, 10:10 PM   #8
norcalal
We in California have the worst gas for old cars. However, I have added Any transmission fluid to gas just before filling up with name brand gas, and am over six or seven years sitting without a problem restarting. Cheap, AND it works!
norcalal is offline   Reply With Quote
Old 10-07-2025, 08:42 AM   #9
1928Mik
1928Mik's Avatar
I fill mine up with non-ethanol and put a few glugs of either Sta-Bil, MMO, or Seafoam, whatever I have on the shelf at the time...I also take the carb off and spray it out with carb cleaner. All have worked great for me.....
1928 Niagara Blue Phaeton
1972 Olds 442 Convertible 455 5 speed Restomod
1976 MGB
-Life's Too Short To Drive Boring Cars-
1928Mik is offline   Reply With Quote
Old 10-07-2025, 09:16 AM   #10
The Master Cylinder
The Master Cylinder's Avatar
Can we assume that is Automatic Transmission Fluid? I have heard of this before. How much ATF do you add per gallon?
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 10-07-2025, 09:25 AM   #11
Planojc
Planojc's Avatar
Winter time here I just keep both cars topped off with non ethanol gas.
Planojc is offline   Reply With Quote
Old 10-07-2025, 09:55 AM   #12
Bob Bidonde
Bob Bidonde's Avatar
For many decades, I have been storing my A's over Long Island, New York winters with full tanks of 87 Octane ethanol gasoline in them, and no additives the likes of Sta-bil or Marvel Mystery Oil.
Bob Bidonde
Old 10-07-2025, 10:06 AM   #13
alexiskai
alexiskai's Avatar
Worth noting that the test performed in the video is a 20-month storage, so more than a year and a half, with 10% ethanol.
Old 10-07-2025, 10:17 AM   #14
SAXBY2
If any one has gas.leaf blowers and other equip. loaded up with crap gas, wait for the seals to rot and carbs clogged. We'd lose the tiny carbs yearly. Stabil does work with the fuel oil mix to keep them going. Same thing in old cars. The Farm test person does comprehensive tests on scores of products so one can see the results, rather than just rely on opinions without some back up..
SAXBY2 is offline   Reply With Quote
